Pc case wont fit back in with the cd/dvd drive after pulling it off for cleaning
ged2121
Pc case front wont fit with the dvd/cd disk after I took it off to dust off the filter it has. Pc case corsair carbride spec 01. Don't know the exact name of the disk sorry. Thank in advance
Not much that we can tell you from that. The only thing that I can think of is that, in my case, the external drives have to be installed after the front panel is in place; you may have to remove the drive, put the panel back, and re-install the drive. I suggest that you get help from a friend with more PC building experience, as if this is unfamiliar to you the above may make things even worse.
I have the Spec 01, love it for what it is, but otherwise..... You can replace the front with the DVD drive in place, but I have found it MUCH easier to remove it first, then put the front back on.
