PC Comparison help
Hambros
51
Is there any significant between this
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor ($329.99 @ Amazon)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler ($109.99 @ Amazon)
Motherboard: Gigabyte GA-Z97X-UD3H ATX LGA1150 Motherboard ($149.99 @ Amazon)
Memory: G.Skill Sniper Gaming Series 16GB (2 x 8GB) DDR3-1600 Memory ($144.99 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk ($89.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($54.44 @ Amazon)
Video Card: Gigabyte GeForce GTX 780 3GB WINDFORCE Video Card (2-Way SLI) ($459.99 @ Newegg)
Case: Corsair 300R ATX Mid Tower Case ($69.99 @ Amazon)
Power Supply: SeaSonic M12II 850W 80+ Bronze Certified Semi-Modular ATX Power Supply ($109.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.99 @ Newegg)
Total: $1999.34
And this
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8589251&CatId=1886
If I were to Crossfire and throw another 290x in it?
Same CPU
Tiger has 16GB ram - but only 1333
Tiger only has r9 290x - 2 780's will kill it.
Tiger doesn't say what make and model power supply. For 2 x 290x you'd need a good quality 1000W
That's too bad. Thanks for the help
I did actually mention crossfiring in my original post.
Why do you suppose that the guys posting their High-End Intel-Based builds (competing with eachother, of course) use the 4770k, or even 4670k, then?
The 4790k was released relatively recently while the 4770k and 4670k have been out for two years now.
I don't mean to continuously burden all of you, but have you taken a look at the High-End Intel-Based PC Build discussion? Could you give me your own 2 cents about which build is ideal?
That really depends on what you mean by ideal. Another major factor is the budget being involved.
I specialize in bang for your buck builds, so if you wanted to make another thread asking for a system and used the format mentioned here:
http://www.tomshardware.com/forum/353572-31-build-upgrade-advice
I'd be happy to help, just send me a pm with the link to your thread :)
* I'm off for today ( last post)
