2 2.yash2003 May 28, 2018 20 0 10 May 30, 2018 #1 Ryzen 7 2700X 16 GB RAM and ETC. Thanks! Build: https://in.pcpartpicker.com/user/YashKumar/saved/GPZtJx
Solution Barty1884 May 30, 2018 Looks really solid. What's the intended use though? For productivity, it's a great system. For gaming, you'd probably be better served by somethign like an R5 2600 + GTX1070 (or 1070TI)
Barty1884 Retired Moderator Apr 16, 2015 22,254 1,355 108,740 May 30, 2018 Solution #2 Looks really solid. What's the intended use though? For productivity, it's a great system. For gaming, you'd probably be better served by somethign like an R5 2600 + GTX1070 (or 1070TI) Upvote 0 Downvote Solution
