PC completely loses power while gaming
wolve2118
Commendable
May 27, 2016
5
Lately my computer has just been losing complete power while gaming like someone has just pulled the power cord out. Originally I thought it would only do it when I would play CSGO whenever I loaded any map, which is odd as I play on extremely low settings. (1280x960) black bars.
It also completely loses power when I tried Overwatch for about 5 minutes. Also when doing a benchmark test using PCmark, and also doing a benchmark on Bioshock infinite. Fallout 4 Idled on high graphics 1080p as well.
It does not crash when idle, or using chrome, so far only when playing a game or using the benchmark tool.
PC Specs:
Motherboard: ASRock Fatal1ty Z97 Killer
GPU: Sapphire AMD Radeon R9 290 4GB Overclocked Tri-X Video Card
CPU: Intel Core i5 4690K Quad Core LGA 1150 3.5GHz
PSU: Cooler Master V750 Vanguard Series 750W
Ram: G.SKILL RipjawsX 8GB (2x 4GB) DDR3
Misc:
Cooler Master Seidon 120V 120mm Liquid CPU Cooler
Seagate ST2000DM001 2TB Barracuda Desktop HDD 3.5” 7200RPM SATA3
Intel 520 120GB 2.5" SATA III MLC SSD OEM SSDSC2CW120A310
So far I have tried:
Ram memory diagnostic
Updating the bios
Updating all drivers for CPU, GPU, Sound etc
Upgrading to Windows 10
Re-Installing games
Using different power points around my house
Virus scans
Taken apart the case and cleaned out the fans and anything else.
Computer is about 2 years old, never had an issue before, before this I always had no trouble playing all games on ultra. I've never had a problem with over heating of any kind and always had low temperatures.
I was thinking it may be the PSU, but that doesn't make any sense as it wasn't a bad one and it's not exactly old, and I don't actually use my PC that often besides maybe 2 hours a day for some gaming. I'm really hoping it isn't as I have no alternate PSU to test with, and I can't exactly afford a new one at this point in time.
Any help is greatly appreciated.
Is this what you mean?
https://i.gyazo.com/a714414aea56076c3dc9d96042c7dde5.png
I'm not sure how you log using that program unless it's it's just this window and you don't need to do anything specific.
https://i.gyazo.com/09bc47f132f76e6ae987f7626cdecd8f.png
The CPU and GPU temps are always fine and cool, I've tried re-installing windows as well. :/
I have the log file, what do you want me to post or how do I view it properly? I can only open it in notepad and its a lot of random numbers and things.
Here is just all the text from the file if it's useful
Date,Time,"Virtual Memory Commited [MB]","Virtual Memory Available [MB]","Virtual Memory Load [%]","Physical Memory Used [MB]","Physical Memory Available [MB]","Physical Memory Load [%]","Page File Usage [%]","Core #0 VID [V]","Core #1 VID [V]","Core #2 VID [V]","Core #3 VID [V]","Core #0 Clock [MHz]","Core #1 Clock [MHz]","Core #2 Clock [MHz]","Core #3 Clock [MHz]","Bus Clock [MHz]","Uncore Clock [MHz]","PCIe Clock [MHz]","Core #0 Usage [%]","Core #1 Usage [%]","Core #2 Usage [%]","Core #3 Usage [%]","Max CPU/Thread Usage [%]","Total CPU Usage [%]","On-Demand Clock Modulation [%]","Core #0 Thermal Throttling [Yes/No]","Core #1 Thermal Throttling [Yes/No]","Core #2 Thermal Throttling [Yes/No]","Core #3 Thermal Throttling [Yes/No]","Core #0 Ratio [x]","Core #1 Ratio [x]","Core #2 Ratio [x]","Core #3 Ratio [x]","Uncore Ratio [x]","Package/Ring Thermal Throttling [Yes/No]","Core #0 [°C]","Core #1 [°C]","Core #2 [°C]","Core #3 [°C]","Core #0 Distance to TjMAX [°C]","Core #1 Distance to TjMAX [°C]","Core #2 Distance to TjMAX [°C]","Core #3 Distance to TjMAX [°C]","Core Max [°C]","CPU Package [°C]","CPU IA Cores [°C]","CPU GT Cores (Graphics) [°C]","CPU Package Power [W]","IA Cores Power [W]","Total DRAM Power [W]","Memory Clock [MHz]","Memory Clock Ratio [x]","Tcas [T]","Trcd [T]","Trp [T]","Tras [T]","Trfc [T]","Command Rate [T]","IA: PROCHOT [Yes/No]","IA: Thermal Event [Yes/No]","IA: Graphics Driver [Yes/No]","IA: Autonomous Utilization-Based Frequency Control [Yes/No]","IA: VR Thermal Alert [Yes/No]","IA: Electrical Design Point/Other (ICCmax,PL4,SVID,DDR RAPL) [Yes/No]","IA: Domain-Level PBM PL1 [Yes/No]","IA: Package-Level RAPL/PBM PL1 [Yes/No]","IA: Package-Level RAPL/PBM PL2,PL3 [Yes/No]","IA: Max Turbo Limit [Yes/No]","IA: Turbo Attenuation (MCT) [Yes/No]","GT: PROCHOT [Yes/No]","GT: Thermal Event [Yes/No]","GT: Graphics Driver [Yes/No]","GT: VR Thermal Alert [Yes/No]","GT: Max VR Voltage, ICCmax, PL4 [Yes/No]","GT: Domain-Level PBM PLGT [Yes/No]","GT: Package-Level RAPL/PBM PL1 [Yes/No]","GT: Package-Level RAPL/PBM PL2,PL3 [Yes/No]","RING: Thermal Event [Yes/No]","RING: Residency State Regulation [Yes/No]","RING: Running Average Thermal Limit [Yes/No]","RING: VR Thermal Alert [Yes/No]","RING: VR TDC [Yes/No]","RING: Max VR Voltage, ICCmax, PL4 [Yes/No]","RING: Domain-Level PBM PL1 [Yes/No]","RING: Package-Level RAPL/PBM PL1 [Yes/No]","RING: Package-Level RAPL/PBM PL2,PL3 [Yes/No]","Motherboard [°C]","CPU [°C]","Auxiliary [°C]","AUXTIN2 [°C]","AUXTIN3 [°C]","CPU (PECI) [°C]","Vccin [V]","+5V [V]","AVCC [V]","+3.3V [V]","+12V [V]","CPU Digital IO [V]","Vcore [V]","3VSB [V]","CPU Digital IO [V]","CPU Analog IO [V]","CPU Cache [V]","CPU SA [V]","VIN14 [V]","Chassis1 [RPM]","CPU1 [RPM]","Chassis3 [RPM]","Chassis2 [RPM]","Chassis Intrusion [Yes/No]","Drive Temperature [°C]","Drive Airflow Temperature [°C]","Drive Failure [Yes/No]","Drive Warning [Yes/No]","Drive Remaining Life [%]","Drive Failure [Yes/No]","Drive Warning [Yes/No]","Total Host Writes [GB]","Total NAND Writes [GB]","Total Host Reads [GB]","Read Activity [%]","Write Activity [%]","Total Activity [%]","Read Rate [MB/s]","Write Rate [MB/s]","Read Total [MB]","Write Total [MB]","Read Activity [%]","Write Activity [%]","Total Activity [%]","Read Rate [MB/s]","Write Rate [MB/s]","Read Total [MB]","Write Total [MB]","GPU Thermal Diode [°C]","GPU Core Voltage (VDDC) [V]","GPU Memory Voltage (MVDDC) [V]","GPU Fan [RPM]","GPU Core Current [A]","GPU Memory Current [A]","GPU Core Power [W]","GPU Memory Power [W]","GPU Clock [MHz]","GPU Memory Clock [MHz]","GPU Utilization [%]","GPU D3D Usage [%]","GPU Memory Controller Utilization [%]","GPU I/O Utilization [%]","GPU Fan Speed [%]","GPU D3D Memory Dedicated [MB]","GPU D3D Memory Dynamic [MB]","PCIe Link Speed [GT/s]","GPU VRM Temperature1 [°C]","GPU VRM Temperature2 [°C]","GPU VRM Voltage Out (VOUT/VID) [V]","GPU VRM Voltage In (VIN/+12V) [V]","GPU VRM Current In (IIN) [A]","GPU VRM Current Out (IOUT) [A]","GPU VRM Power Out (POUT) [W]","GPU VRM Power In (PIN) [W]","GPU VRM Temperature1 [°C]","GPU VRM Temperature2 [°C]","GPU VRM Voltage Out (VOUT/VID) [V]","GPU VRM Voltage In (VIN/+12V) [V]","GPU VRM Current In (IIN) [A]","GPU VRM Current Out (IOUT) [A]","GPU VRM Power Out (POUT) [W]","GPU VRM Power In (PIN) [W]","Total DL [MB]","Total UP [MB]","Current DL rate [KB/s]","Current UP rate [KB/s]","Total DL [MB]","Total UP [MB]","Current DL rate [KB/s]","Current UP rate [KB/s]","Total Errors []",
28.5.2016,11:35:11.567,3479,6583,34.5,2850,5292,35.0,0.0,1.199,1.202,1.198,1.198,1799.5,1799.5,3498.9,3498.9,100.0,1799.5,100.0,15.3,24.8,13.1,9.4,24.8,15.7,100.0,No,No,No,No,18,18,35,35,18,No,22,23,26,28,78,77,74,72,28,27,27,25,12.943,6.282,1.218,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,23.0,25.0,27.0,26.0,106.0,25.0,1.760,4.992,3.328,3.312,11.904,1.008,0.840,3.472,1.008,1.008,0.768,0.840,0.216,2089,1748,646,1875,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.0,0.0,0.000,0.000,823,16,0.5,2.5,3.0,0.592,0.292,1355,1366,34,0.988,1.000,1421,9.000,101.000,8.888,101.000,300.0,1299.0,0.0,3.2,0.0,0.0,20.0,487,60,2.5,26.0,25.0,0.987,11.688,0.750,9.500,14.281,10.219,25.0,26.0,1.001,11.688,2.828,25.250,25.250,33.000,130,6,30.254,3.775,130,6,30.254,3.775,0,
28.5.2016,11:35:13.717,3474,6588,34.5,2851,5291,35.0,0.0,1.199,1.202,1.198,1.198,799.8,799.8,799.8,799.8,100.0,799.8,100.0,15.2,30.4,21.0,11.5,30.4,19.5,100.0,No,No,No,No,8,8,8,8,8,No,23,21,22,23,77,79,78,77,23,25,23,25,12.277,5.723,1.212,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,23.0,25.0,33.0,26.0,106.0,25.0,1.760,4.992,3.312,3.312,11.904,1.008,0.976,3.472,1.008,1.000,0.792,0.840,0.216,1065,1717,647,1877,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.0,0.0,0.000,0.000,823,16,0.0,0.1,0.2,0.007,0.177,1355,1366,34,0.988,1.000,1420,9.000,101.000,8.888,101.000,300.0,299.0,19.0,2.4,0.0,0.0,20.0,487,60,2.5,26.0,25.0,0.988,11.688,0.563,7.500,7.406,6.563,25.0,26.0,1.001,11.688,0.266,3.500,9.250,23.000,130,6,26.656,4.094,130,6,26.656,4.094,0,
28.5.2016,11:35:15.886,3490,6573,34.6,2851,5292,35.0,0.0,1.199,1.202,1.198,1.198,799.8,799.8,799.8,799.8,100.0,799.8,100.0,13.8,19.7,24.0,13.1,24.0,17.6,100.0,No,No,No,No,8,8,8,8,8,No,22,21,24,24,78,79,76,76,24,25,24,25,16.399,8.961,1.299,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,23.0,25.0,30.0,26.0,106.0,25.0,1.760,4.992,3.312,3.312,11.904,1.008,0.896,3.472,1.008,1.000,0.768,0.840,0.216,1055,1719,643,1877,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.0,0.0,0.000,0.000,823,16,0.9,2.6,3.5,0.029,0.812,1355,1368,34,0.988,1.000,1418,8.000,7.000,7.900,7.000,300.0,149.5,0.0,0.0,2.0,0.0,20.0,503,60,2.5,26.0,26.0,0.989,11.688,0.531,7.000,7.406,6.563,26.0,26.0,1.001,11.688,0.156,1.750,1.750,1.813,130,6,154.500,5.890,130,6,154.500,5.890,0,
28.5.2016,11:35:18.028,3665,6398,36.4,2963,5180,36.3,0.0,1.199,1.202,1.198,1.198,3899.0,3899.0,3899.0,3899.0,100.0,3899.0,100.0,39.5,18.7,28.7,29.4,39.5,29.1,100.0,No,No,No,No,39,39,39,39,39,No,27,25,28,26,73,75,72,74,28,26,26,25,27.700,19.277,1.585,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,28.5,15.0,26.0,106.0,28.0,1.760,4.992,3.312,3.296,11.904,1.008,0.920,3.472,1.008,1.000,1.016,0.840,0.216,1057,1744,645,1872,No,23,23,No,No,100.0,No,No,2524,2450,2877,17.2,0.0,17.2,11.247,0.001,846,16,0.3,0.1,0.5,0.157,0.170,1355,1368,35,0.988,1.000,1416,10.000,101.000,9.875,101.000,300.0,1299.0,0.0,8.5,0.0,0.0,20.0,499,79,2.5,26.0,26.0,0.987,11.656,0.750,9.500,9.344,8.719,26.0,26.0,1.001,11.656,2.875,25.500,25.500,33.313,131,6,270.176,37.045,131,6,270.176,37.045,0,
28.5.2016,11:35:20.169,3631,6431,36.0,2947,5195,36.1,0.0,1.199,1.202,1.198,1.198,3898.8,3898.8,3898.8,3898.8,100.0,3898.8,100.0,28.9,17.3,10.8,12.3,28.9,17.3,100.0,No,No,No,No,39,39,39,39,39,No,26,26,25,26,74,74,75,74,26,26,26,26,22.794,13.605,1.451,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,23.0,26.0,28.0,26.0,106.0,26.0,1.760,4.992,3.312,3.296,11.808,1.008,1.040,3.472,1.008,1.000,1.016,0.840,0.216,0,1735,645,1875,No,23,23,No,No,100.0,No,No,2524,2450,2877,11.4,1.3,12.7,7.344,3.454,861,23,0.0,2.6,2.6,0.000,0.314,1355,1369,36,1.181,1.000,1415,20.000,102.000,23.625,102.000,483.0,1299.0,0.0,20.6,0.0,0.0,20.0,506,80,2.5,26.0,26.0,1.183,11.688,1.781,21.500,18.563,13.813,26.0,26.0,1.001,11.656,2.875,25.500,25.500,33.875,133,6,1006.752,18.260,133,6,1006.752,18.260,0,
28.5.2016,11:35:22.313,3640,6423,36.1,2958,5185,36.3,0.0,1.199,1.202,1.198,1.198,3898.8,3898.8,3898.8,3898.8,100.0,3898.8,100.0,21.3,10.2,2.9,3.6,21.3,9.5,100.0,No,No,No,No,39,39,39,39,39,No,24,25,25,25,76,75,75,75,25,26,26,26,18.535,10.459,1.312,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,25.5,35.0,26.0,106.0,25.0,1.776,4.992,3.312,3.296,11.808,1.008,0.888,3.472,1.008,1.000,0.888,0.840,0.216,1053,1719,642,1875,No,23,23,No,No,100.0,No,No,2524,2450,2877,1.4,0.4,1.8,0.020,1.468,861,26,0.0,0.0,0.0,0.000,0.000,1355,1369,36,0.981,1.000,1412,10.000,102.000,9.813,102.000,300.0,1299.0,0.0,17.7,0.0,0.0,20.0,507,80,2.5,26.0,26.0,1.184,11.688,1.969,21.000,16.156,13.875,26.0,26.0,1.001,11.656,2.875,25.500,25.500,33.875,134,6,449.348,28.962,134,6,449.348,28.962,0,
28.5.2016,11:35:24.461,3638,6425,36.1,2953,5189,36.2,0.0,1.199,1.202,1.198,1.198,3898.7,3898.7,3898.7,3898.7,100.0,3898.7,100.0,15.2,5.7,6.5,15.9,15.9,10.8,100.0,No,No,No,No,39,39,39,39,39,No,25,22,24,24,75,78,76,76,25,26,24,26,19.280,11.291,1.318,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,23.0,25.5,31.0,26.0,106.0,25.0,1.760,4.992,3.312,3.296,11.808,1.008,0.840,3.472,1.008,1.000,0.944,0.840,0.216,2122,1741,643,1877,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.9,0.9,0.000,2.928,861,32,1.0,0.0,1.0,1.689,0.007,1359,1369,36,0.988,1.000,1412,20.000,103.000,19.750,103.000,300.0,1299.0,88.0,10.6,50.0,0.0,20.0,507,80,2.5,26.0,27.0,0.983,11.656,1.781,14.000,23.063,22.219,27.0,26.0,1.001,11.656,2.875,25.750,25.500,33.500,134,6,320.079,8.537,134,6,320.079,8.537,0,
28.5.2016,11:35:26.621,3639,6424,36.1,2948,5195,36.2,0.0,1.199,1.202,1.198,1.198,3498.9,3498.9,3498.9,3498.9,100.0,3498.9,100.0,11.6,5.8,2.9,5.1,11.6,6.3,100.0,No,No,No,No,35,35,35,35,35,No,22,22,23,22,78,78,77,78,23,25,23,25,13.202,6.481,1.175,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,25.5,38.0,26.0,106.0,25.0,1.760,4.992,3.312,3.296,11.808,1.008,0.816,3.472,1.008,1.000,0.768,0.840,0.216,0,1744,642,1875,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.8,0.8,0.000,2.549,861,37,0.0,0.1,0.1,0.000,0.244,1359,1369,36,1.188,1.000,1413,19.000,102.000,22.563,102.000,483.0,1299.0,0.0,16.2,0.0,0.0,20.0,507,80,2.5,26.0,27.0,1.185,11.656,1.188,20.500,18.563,13.875,27.0,26.0,1.001,11.625,2.875,25.500,25.500,33.875,135,6,62.026,4.248,135,6,62.026,4.248,0,
28.5.2016,11:35:28.763,3636,6427,36.1,2944,5198,36.1,0.0,1.199,1.202,1.198,1.198,3499.0,3499.0,3499.0,3499.0,100.0,3499.0,100.0,15.2,7.2,6.5,3.6,15.2,8.1,100.0,No,No,No,No,35,35,35,35,35,No,24,22,23,23,76,78,77,77,24,25,23,25,12.732,6.089,1.216,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,25.0,37.0,26.0,106.0,25.0,1.760,4.968,3.312,3.296,11.904,1.008,0.776,3.472,1.008,1.000,0.880,0.840,0.216,1077,1739,643,1875,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.3,0.3,0.000,1.101,861,39,0.1,0.1,0.1,0.005,0.065,1359,1369,37,0.988,1.000,1412,11.000,102.000,10.863,102.000,300.0,1299.0,42.0,17.0,12.0,0.0,20.0,508,80,2.5,26.0,27.0,0.984,11.656,1.500,13.000,24.250,21.844,27.0,26.0,1.001,11.688,2.875,25.750,25.500,33.563,135,6,33.587,4.122,135,6,33.587,4.122,0,
28.5.2016,11:35:30.899,3520,6542,34.9,2963,5179,36.3,0.0,1.199,1.202,1.198,1.198,1599.5,1599.5,799.8,799.8,100.0,1599.5,100.0,27.0,19.7,10.9,23.3,27.0,20.2,100.0,No,No,No,No,16,16,8,8,16,No,23,23,25,25,77,77,75,75,25,26,24,26,23.656,15.376,1.476,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,26.5,27.0,26.0,106.0,26.0,1.760,4.992,3.312,3.296,11.904,1.008,1.008,3.472,1.008,1.000,0.800,0.840,0.216,2188,1739,641,1875,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.1,0.1,0.000,0.376,861,40,0.1,4.0,4.1,0.133,1.572,1359,1373,36,0.981,1.000,1414,11.000,102.000,10.794,102.000,300.0,1299.0,0.0,13.6,0.0,0.0,20.0,362,55,2.5,26.0,27.0,0.980,11.688,0.906,16.500,14.688,11.656,27.0,26.0,1.001,11.688,2.875,25.500,25.500,33.875,135,6,52.901,3.609,135,6,52.901,3.609,0,
28.5.2016,11:35:33.049,3484,6578,34.6,2948,5194,36.2,0.0,1.199,1.202,1.198,1.198,1599.6,1599.6,1599.6,1599.6,100.0,1599.6,100.0,24.0,13.1,10.9,11.6,24.0,14.9,100.0,No,No,No,No,16,16,16,16,16,No,23,22,23,24,77,78,77,76,24,26,23,26,15.286,8.350,1.326,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,25.0,30.0,26.0,106.0,25.0,1.760,4.992,3.312,3.312,11.904,1.008,0.816,3.472,1.008,1.000,0.840,0.840,0.216,1062,1741,640,1877,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.0,0.0,0.000,0.000,861,40,0.1,1.5,1.6,0.026,1.232,1359,1375,37,0.981,1.000,1413,10.000,102.000,9.813,102.000,300.0,1299.0,0.0,12.9,0.0,0.0,20.0,364,55,2.5,26.0,27.0,0.985,11.656,1.375,11.500,17.094,12.031,27.0,26.0,1.001,11.625,2.859,25.500,25.500,33.375,135,6,341.447,15.136,135,6,341.447,15.136,0,
28.5.2016,11:35:35.186,3562,6501,35.3,2998,5144,36.8,0.0,1.199,1.202,1.198,1.198,3899.0,3899.0,3899.0,3899.0,100.0,3899.0,100.0,28.4,17.5,16.7,10.2,28.4,18.2,100.0,No,No,No,No,39,39,39,39,39,No,26,26,26,25,74,74,74,75,26,27,27,26,22.609,13.995,1.437,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,26.5,15.0,26.0,106.0,26.0,1.760,4.992,3.312,3.312,11.904,1.016,1.208,3.472,1.008,1.000,1.104,0.840,0.216,1077,1737,640,1875,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.0,0.0,0.000,0.001,861,40,0.1,1.8,2.0,0.004,1.532,1359,1378,37,1.188,1.000,1413,22.000,102.000,26.125,102.000,483.0,1299.0,10.0,12.4,4.0,0.0,20.0,386,56,2.5,26.0,27.0,1.187,11.656,1.250,12.000,22.469,13.813,27.0,26.0,1.001,11.656,2.906,25.500,25.500,33.875,137,6,715.972,35.498,137,6,715.972,35.498,0,
28.5.2016,11:35:37.331,3532,6530,35.1,2960,5182,36.3,0.0,1.199,1.202,1.198,1.198,3899.0,3899.0,3899.0,3899.0,100.0,3899.0,100.0,22.4,5.0,7.2,6.5,22.4,10.3,100.0,No,No,No,No,39,39,39,39,39,No,25,24,25,24,75,76,75,76,25,26,25,26,18.841,11.002,1.320,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,25.5,39.0,26.0,106.0,25.0,1.760,4.992,3.312,3.296,11.904,1.008,0.888,3.472,1.016,1.000,0.904,0.840,0.216,1067,1715,1266,1877,No,23,23,No,No,100.0,No,No,2524,2450,2877,1.9,0.0,1.9,0.529,0.000,862,40,0.1,0.5,0.6,0.015,0.674,1359,1380,37,1.188,1.000,1411,44.000,106.000,52.250,106.000,483.0,1299.0,43.0,17.0,19.0,0.0,20.0,393,58,8.0,26.0,27.0,0.982,11.656,1.594,13.500,23.656,22.219,27.0,26.0,1.001,11.656,2.859,25.750,25.500,33.375,138,6,360.164,9.161,138,6,360.164,9.161,0,
28.5.2016,11:35:39.489,3596,6467,35.7,2998,5144,36.8,0.0,1.199,1.202,1.198,1.198,3899.0,3899.0,3899.0,3899.0,100.0,3899.0,100.0,27.0,4.3,9.4,10.9,27.0,12.9,100.0,No,No,No,No,39,39,39,39,39,No,27,33,28,28,73,67,72,72,33,29,29,26,18.951,10.917,1.398,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,28.0,32.0,26.0,106.0,28.0,1.760,4.992,3.312,3.312,11.904,1.016,1.208,3.472,1.008,1.008,1.104,0.840,0.216,1063,1741,640,1877,No,23,23,No,No,100.0,No,No,2524,2450,2877,16.3,9.0,25.3,1.507,0.039,865,40,0.0,2.9,2.9,0.000,1.008,1359,1382,37,0.988,1.000,1414,10.000,7.000,9.875,7.000,300.0,149.5,0.0,0.0,2.0,0.0,20.0,500,71,2.5,26.0,28.0,0.988,11.688,0.531,7.000,7.406,6.563,28.0,26.0,1.001,11.688,0.156,1.750,1.750,1.813,138,6,349.772,10.381,138,6,349.772,10.381,0,
28.5.2016,11:35:41.687,3563,6500,35.4,3001,5142,36.8,0.0,1.199,1.202,1.198,1.198,799.8,799.8,1999.4,1999.4,100.0,799.8,100.0,24.6,21.0,13.0,16.6,24.6,18.8,100.0,No,No,No,No,8,8,20,20,8,No,22,22,24,25,78,78,76,75,25,25,25,25,14.681,7.547,1.251,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,25.5,26.0,26.0,106.0,25.0,1.776,4.992,3.328,3.312,11.904,1.016,1.064,3.472,1.008,1.000,0.768,0.840,0.216,1071,1744,644,1880,No,23,23,No,No,100.0,No,No,2524,2450,2877,77.2,0.0,77.2,32.196,0.000,932,40,0.0,0.5,0.5,0.000,0.836,1359,1383,35,0.988,1.000,1421,7.000,7.000,6.913,7.000,300.0,149.5,0.0,0.0,2.0,0.0,20.0,500,71,2.5,26.0,27.0,0.989,11.688,0.531,7.000,6.906,6.188,27.0,26.0,1.001,11.688,0.156,1.750,1.750,1.813,139,6,423.441,13.541,139,6,423.441,13.541,0,
28.5.2016,11:35:43.844,3601,6462,35.7,3067,5076,37.6,0.0,1.199,1.202,1.198,1.198,1399.6,1399.6,1399.6,1399.6,100.0,1399.6,100.0,19.2,12.8,30.0,20.0,30.0,20.5,100.0,No,No,No,No,14,14,14,14,14,No,23,21,23,24,77,79,77,76,24,25,24,25,12.646,6.121,1.192,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,25.0,39.0,26.0,106.0,25.0,1.776,4.992,3.328,3.312,11.904,1.008,0.928,3.472,1.008,1.000,0.784,0.840,0.216,1067,1726,644,1882,No,23,23,No,No,100.0,No,No,2524,2450,2877,93.1,0.0,93.1,39.470,0.000,1014,40,0.0,0.2,0.2,0.000,0.294,1359,1384,35,0.988,1.000,1423,7.000,7.000,6.913,7.000,300.0,149.5,0.0,0.0,2.0,0.0,20.0,500,71,2.5,26.0,26.0,0.989,11.688,0.531,7.000,6.906,6.188,26.0,26.0,1.001,11.688,0.156,1.750,1.750,1.813,140,6,324.989,11.584,140,6,325.658,11.584,0,
28.5.2016,11:35:46.002,3639,6423,36.1,3025,5117,37.1,0.0,1.199,1.202,1.198,1.198,3898.6,3898.6,3898.6,3898.6,100.0,3898.6,100.0,43.8,20.1,15.8,16.5,43.8,24.1,100.0,No,No,No,No,39,39,39,39,39,No,28,25,26,27,72,75,74,73,28,28,28,27,22.925,14.155,1.442,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,27.5,15.0,26.0,106.0,27.0,1.760,4.992,3.312,3.312,11.904,1.016,1.208,3.472,1.008,1.000,1.112,0.840,0.216,1067,1748,647,1882,No,23,23,No,No,100.0,No,No,2524,2450,2877,64.7,0.0,64.7,75.731,0.000,1169,40,0.0,0.5,0.5,0.000,1.095,1359,1386,35,0.988,1.000,1424,7.000,7.000,6.913,7.000,300.0,149.5,0.0,0.0,2.0,0.0,20.0,500,71,2.5,26.0,26.0,0.989,11.688,0.531,7.000,6.906,6.188,26.0,26.0,1.001,11.688,0.156,1.750,1.750,1.813,141,6,483.174,16.491,141,6,482.501,16.491,0,
28.5.2016,11:35:48.182,3679,6383,36.5,3104,5038,38.1,0.0,1.199,1.202,1.198,1.198,1199.6,1199.6,1199.6,1199.6,100.0,1199.6,100.0,23.1,18.8,27.5,21.7,27.5,22.8,100.0,No,No,No,No,12,12,12,12,12,No,24,24,25,26,76,76,75,74,26,26,26,25,15.214,8.128,1.307,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,25.5,15.0,26.0,106.0,25.0,1.760,4.992,3.312,3.312,11.904,1.008,0.768,3.472,1.008,1.000,0.792,0.840,0.216,2139,1726,644,1882,No,23,23,No,No,100.0,No,No,2524,2450,2877,79.4,0.0,79.4,43.282,0.000,1259,40,0.0,0.3,0.3,0.000,0.653,1359,1388,35,0.994,1.000,1424,7.000,7.000,6.956,7.000,300.0,149.5,0.0,0.0,2.0,0.0,20.0,500,71,2.5,26.0,26.0,0.989,11.688,0.531,7.000,6.906,6.188,26.0,26.0,1.001,11.688,0.156,1.750,1.750,1.813,142,6,405.395,12.191,142,6,405.395,12.191,0,
28.5.2016,11:35:50.357,3740,6322,37.1,3213,4930,39.4,0.0,1.199,1.202,1.198,1.198,1399.5,1399.5,1399.5,1399.5,100.0,1399.5,100.0,22.3,8.6,27.3,15.1,27.3,18.3,100.0,No,No,No,No,14,14,14,14,14,No,22,23,24,25,78,77,76,75,25,25,25,25,12.782,6.139,1.286,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,25.0,40.0,26.0,106.0,25.0,1.776,4.992,3.312,3.312,11.904,1.008,0.776,3.472,1.008,1.000,0.792,0.840,0.216,1083,1728,645,1882,No,23,23,No,No,100.0,No,No,2524,2450,2877,92.7,0.0,92.7,65.651,0.000,1394,40,0.0,0.6,0.6,0.000,1.217,1359,1390,35,0.988,1.000,1424,8.000,7.000,7.900,7.000,300.0,149.5,0.0,0.0,2.0,0.0,20.0,500,71,2.5,26.0,26.0,0.989,11.688,0.531,7.000,6.906,6.188,26.0,26.0,1.001,11.688,0.156,1.750,1.750,1.813,143,6,439.042,9.814,143,6,439.042,9.814,0,
28.5.2016,11:35:52.526,3820,6242,37.9,3322,4821,40.7,0.0,1.199,1.202,1.198,1.198,3898.7,3898.7,3898.7,3898.7,100.0,3898.7,100.0,20.8,4.3,30.2,9.3,30.2,16.1,100.0,No,No,No,No,39,39,39,39,39,No,22,22,23,24,78,78,77,76,24,26,25,26,13.250,6.332,1.301,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,25.0,28.0,26.0,106.0,25.0,1.760,4.992,3.312,3.312,11.904,1.008,0.808,3.472,1.008,1.000,0.888,0.840,0.216,1082,1744,642,1880,No,23,23,No,No,100.0,No,No,2524,2450,2877,90.8,0.0,90.8,64.588,0.000,1529,40,0.0,2.8,2.8,0.000,1.118,1359,1392,34,0.988,1.000,1424,7.000,7.000,6.913,7.000,300.0,149.5,0.0,0.0,1.0,0.0,20.0,500,71,2.5,26.0,26.0,0.989,11.688,0.531,7.000,6.906,6.188,26.0,26.0,1.001,11.688,0.141,1.750,1.750,1.641,144,6,416.295,9.768,144,6,416.295,9.768,0,
28.5.2016,11:35:54.699,3922,6141,38.9,3418,4724,41.9,0.0,1.199,1.202,1.198,1.198,1599.6,1599.6,1599.6,1599.6,100.0,1599.6,100.0,24.4,6.4,26.6,11.5,26.6,17.2,100.0,No,No,No,No,16,16,16,16,16,No,22,22,24,25,78,78,76,75,25,25,24,25,12.586,5.995,1.328,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,25.0,20.0,26.0,106.0,25.0,1.760,4.992,3.312,3.312,11.904,1.016,0.856,3.472,1.008,1.000,0.768,0.840,0.216,1057,1724,645,1880,No,23,23,No,No,100.0,No,No,2524,2450,2877,81.7,0.0,81.7,54.550,0.000,1642,40,0.0,0.1,0.1,0.000,0.252,1359,1393,34,0.988,1.000,1423,8.000,7.000,7.900,7.000,300.0,149.5,0.0,0.0,1.0,0.0,20.0,500,71,2.5,26.0,25.0,0.989,11.688,0.531,7.000,6.906,6.188,25.0,26.0,1.001,11.688,0.156,1.750,1.750,1.813,145,6,508.690,17.102,145,6,508.690,17.102,0,
28.5.2016,11:35:56.835,4013,6049,39.8,3533,4609,43.3,0.0,1.199,1.202,1.198,1.198,2499.3,2499.3,2499.3,2499.3,100.0,2499.3,100.0,22.3,13.6,31.6,15.1,31.6,20.6,100.0,No,No,No,No,25,25,25,25,25,No,24,22,24,24,76,78,76,76,24,26,24,26,14.370,7.326,1.368,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,25.5,25.0,26.0,106.0,25.0,1.776,4.992,3.312,3.312,11.904,1.008,1.048,3.472,1.008,1.000,0.896,0.840,0.216,1083,1739,645,1882,No,23,23,No,No,100.0,No,No,2524,2450,2877,88.2,0.0,88.2,61.429,0.000,1768,40,0.0,2.6,2.6,0.000,0.814,1359,1395,34,0.988,1.000,1422,7.000,7.000,6.913,7.000,300.0,149.5,0.0,0.0,2.0,0.0,20.0,500,71,2.5,26.0,25.0,0.988,11.688,0.594,7.500,7.406,6.938,25.0,26.0,1.001,11.688,0.156,1.750,1.750,1.813,146,7,571.534,12.298,146,7,571.534,12.298,0,
28.5.2016,11:35:59.026,4276,5787,42.4,3775,4368,46.3,0.0,1.199,1.202,1.198,1.198,3498.9,3498.9,3498.9,3498.9,100.0,3498.9,100.0,37.2,8.0,13.1,8.7,37.2,16.8,100.0,No,No,No,No,35,35,35,35,35,No,24,22,24,23,76,78,76,77,24,26,26,26,14.995,7.756,1.434,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,25.0,27.0,26.0,106.0,25.0,1.760,4.992,3.312,3.312,11.904,1.008,0.904,3.472,1.008,1.000,0.800,0.840,0.216,2136,1721,642,1877,No,23,23,No,No,100.0,No,No,2524,2450,2877,84.1,0.0,84.1,57.330,0.000,1886,40,0.0,0.2,0.2,0.000,0.325,1359,1395,34,0.988,1.000,1424,7.000,7.000,6.913,7.000,300.0,149.5,0.0,0.0,2.0,0.0,20.0,500,71,2.5,26.0,25.0,0.989,11.688,0.531,7.000,6.906,6.188,25.0,26.0,1.001,11.688,0.156,1.750,1.750,1.813,146,7,256.622,9.404,146,7,256.622,9.404,0,
28.5.2016,11:36:1.152,4337,5725,43.1,3844,4299,47.2,0.0,1.199,1.202,1.198,1.198,3898.7,3898.7,3898.7,3898.7,100.0,3898.7,100.0,28.5,29.2,20.7,28.5,29.2,26.7,100.0,No,No,No,No,39,39,39,39,39,No,35,31,28,28,65,69,72,72,35,29,29,26,26.616,18.268,1.478,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,33.0,35.0,26.0,106.0,33.0,1.744,4.992,3.312,3.296,11.904,1.016,0.872,3.472,1.008,1.008,1.112,0.840,0.216,2093,1719,646,1875,No,23,23,No,No,100.0,No,No,2524,2450,2877,38.9,0.0,38.9,22.831,0.000,1933,40,0.0,0.3,0.3,0.000,0.935,1359,1397,35,0.988,1.000,1417,11.000,101.000,10.863,101.000,300.0,1299.0,0.0,9.1,0.0,0.0,20.0,508,71,2.5,26.0,26.0,0.985,11.656,1.344,12.500,10.813,10.188,26.0,26.0,1.001,11.656,2.656,25.500,25.500,30.938,147,7,458.076,18.565,147,7,458.076,18.565,0,
28.5.2016,11:36:3.296,4334,5728,43.0,3844,4299,47.2,0.0,1.199,1.202,1.198,1.198,3898.8,3898.8,3898.8,3898.8,100.0,3898.8,100.0,41.1,72.7,39.7,83.8,83.8,59.3,100.0,No,No,No,No,39,39,39,39,39,No,32,41,36,39,68,59,64,61,41,39,39,27,52.656,43.094,1.755,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,39.5,15.0,26.0,106.0,39.0,1.728,4.968,3.296,3.280,11.808,1.016,1.208,3.472,1.008,1.008,1.112,0.840,0.216,2086,1711,644,1867,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.0,0.0,0.000,0.000,1933,40,0.0,2.8,2.8,0.000,1.109,1359,1400,41,1.206,1.000,1410,86.000,106.000,103.738,106.000,1000.0,1299.0,65.0,48.8,48.0,0.0,20.0,509,66,8.0,27.0,27.0,1.174,11.594,7.219,73.000,76.000,73.000,27.0,27.0,1.001,11.563,2.703,25.750,26.000,31.313,149,7,510.174,12.251,149,7,510.174,12.251,0,
28.5.2016,11:36:5.435,4346,5716,43.1,3853,4290,47.3,0.0,1.199,1.202,1.198,1.198,3898.8,3898.8,3898.8,3898.8,100.0,3898.8,100.0,42.0,53.2,31.3,58.6,58.6,46.3,100.0,No,No,No,No,39,39,39,39,39,No,28,28,28,26,72,72,72,74,28,28,28,26,47.243,37.393,1.634,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,30.5,15.0,26.0,106.0,30.0,1.760,4.968,3.296,3.296,11.808,1.008,1.208,3.472,1.008,1.000,1.016,0.840,0.216,1068,1741,640,1869,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.0,0.0,0.000,0.000,1933,40,0.0,2.0,2.1,0.013,0.720,1359,1401,41,1.212,1.000,1411,31.000,102.000,37.587,102.000,991.0,1299.0,20.0,34.2,17.0,0.0,20.0,509,66,8.0,28.0,27.0,1.200,11.625,5.469,52.000,61.000,63.563,27.0,28.0,1.001,11.625,2.703,26.000,25.750,31.406,149,7,328.606,14.330,149,7,328.606,14.330,0,
28.5.2016,11:36:7.553,4347,5716,43.1,3853,4290,47.3,0.0,1.199,1.202,1.198,1.198,3898.9,3898.9,3898.9,3898.9,100.0,3898.9,100.0,8.8,9.4,5.8,1.4,9.4,6.4,100.0,No,No,No,No,39,39,39,39,39,No,25,22,25,24,75,78,75,76,25,25,25,25,21.658,12.110,1.215,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,25.5,30.0,26.0,106.0,25.0,1.760,4.992,3.312,3.296,11.808,1.008,0.816,3.472,1.008,1.000,0.896,0.840,0.216,1067,1737,644,1877,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.0,0.0,0.000,0.000,1933,40,0.0,2.7,2.7,0.000,0.953,1359,1403,38,0.981,1.000,1410,12.000,102.000,11.775,102.000,300.0,1299.0,0.0,20.3,0.0,0.0,20.0,509,66,2.5,28.0,27.0,1.185,11.656,1.469,13.000,10.813,9.844,27.0,28.0,1.001,11.688,2.625,25.250,25.500,30.938,150,7,616.777,15.090,150,7,616.777,15.090,0,
28.5.2016,11:36:9.696,5033,5030,50.0,3935,4208,48.3,0.0,1.199,1.202,1.198,1.198,3898.9,3898.9,3898.9,3898.9,100.0,3898.9,100.0,27.9,5.8,17.6,15.4,27.9,16.7,100.0,No,No,No,No,39,39,39,39,39,No,27,28,30,30,73,72,70,70,30,30,30,25,16.913,9.399,1.412,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,26.5,21.0,26.0,106.0,26.0,1.760,4.992,3.312,3.296,11.904,1.008,1.208,3.472,1.008,1.008,1.112,0.840,0.216,0,1724,642,1880,No,23,23,No,No,100.0,No,No,2524,2450,2877,63.1,0.1,63.1,35.687,0.005,2006,40,0.0,0.2,0.2,0.000,0.444,1359,1404,38,1.231,1.000,1422,28.000,7.000,34.475,7.000,1000.0,149.5,82.0,75.7,1.0,0.0,20.0,1004,78,8.0,28.0,26.0,1.228,11.656,2.969,28.500,34.938,34.563,26.0,28.0,1.001,11.656,0.156,1.750,1.750,1.813,151,7,456.024,10.431,151,7,456.024,10.431,0,
28.5.2016,11:36:11.825,5101,4962,50.6,3999,4144,49.1,0.0,1.199,1.202,1.198,1.198,3898.9,3898.9,3898.9,3898.9,100.0,3898.9,100.0,39.4,29.9,30.6,28.4,39.4,32.1,100.0,No,No,No,No,39,39,39,39,39,No,32,38,37,34,68,62,63,66,38,37,37,26,28.471,19.488,1.780,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,30.0,39.0,26.0,106.0,30.0,1.728,4.968,3.296,3.296,11.904,1.016,1.216,3.472,1.016,1.008,0.888,0.840,0.216,1071,1728,641,1880,No,23,23,No,No,100.0,No,No,2524,2450,2877,24.7,0.0,24.7,7.005,0.000,2020,40,0.0,0.4,0.4,0.000,0.843,1359,1406,39,1.219,1.000,1420,35.000,101.000,42.656,101.000,965.0,1299.0,99.0,88.8,2.0,0.0,20.0,1093,114,8.0,28.0,26.0,1.213,11.656,3.375,27.000,20.000,16.750,26.0,28.0,1.001,11.656,1.219,7.000,4.250,4.188,152,7,382.871,16.855,152,7,382.871,16.855,0,
28.5.2016,11:36:14.002,5202,4860,51.6,4057,4085,49.8,0.0,1.199,1.202,1.198,1.198,3898.9,3898.9,3898.9,3898.9,100.0,3898.9,100.0,44.1,41.1,24.2,41.1,44.1,37.6,100.0,No,No,No,No,39,39,39,39,39,No,29,26,27,28,71,74,73,72,29,27,27,27,38.262,28.540,1.853,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,34.5,27.0,26.0,106.0,34.0,1.760,4.992,3.312,3.312,11.904,1.016,1.056,3.472,1.016,1.008,1.112,0.840,0.216,1065,1739,642,1875,No,23,23,No,No,100.0,No,No,2524,2450,2877,6.1,0.0,6.1,1.442,0.000,2023,40,0.0,3.2,3.2,0.000,0.993,1359,1408,36,0.988,1.000,1419,7.000,7.000,6.913,7.000,300.0,149.5,0.0,0.0,1.0,0.0,20.0,1136,121,2.5,28.0,26.0,0.989,11.688,0.531,7.000,6.906,6.188,26.0,28.0,1.001,11.688,0.156,1.750,1.750,1.813,153,7,483.288,15.611,153,7,483.288,15.611,0,
28.5.2016,11:36:16.199,5226,4836,51.9,4079,4064,50.0,0.0,1.199,1.202,1.198,1.198,3898.9,3898.9,3898.9,3898.9,100.0,3898.9,100.0,17.1,29.2,41.4,12.8,41.4,25.1,100.0,No,No,No,No,39,39,39,39,39,No,30,33,31,29,70,67,69,71,33,33,33,26,30.204,21.212,1.659,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,34.0,18.0,26.0,106.0,34.0,1.744,4.968,3.296,3.280,11.808,1.008,1.208,3.472,1.008,1.000,1.072,0.840,0.216,1065,1739,642,1869,No,23,23,No,No,100.0,No,No,2524,2450,2877,38.5,5.5,44.0,6.222,0.012,2036,40,0.0,0.5,0.5,0.000,1.101,1359,1410,41,1.194,1.000,1415,58.000,102.000,69.238,102.000,991.0,1299.0,71.0,61.9,18.0,0.0,20.0,1139,122,8.0,28.0,26.0,1.195,11.594,10.281,88.000,87.375,94.750,26.0,28.0,1.001,11.625,2.734,26.000,26.000,31.688,154,7,491.265,18.182,154,7,491.265,18.182,0,
28.5.2016,11:36:18.359,5220,4843,51.8,4088,4054,50.2,0.0,1.199,1.202,1.198,1.198,3898.9,3898.9,3898.9,3898.9,100.0,3898.9,100.0,37.1,32.8,58.5,34.2,58.5,40.7,100.0,No,No,No,No,39,39,39,39,39,No,31,32,30,31,69,68,70,69,32,33,33,26,39.342,29.738,2.049,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,33.0,15.0,26.0,106.0,33.0,1.744,4.992,3.312,3.312,11.904,1.008,0.880,3.472,1.008,1.000,1.080,0.840,0.216,0,1717,641,1867,No,23,23,No,No,100.0,No,No,2524,2450,2877,9.5,3.4,12.9,4.390,0.197,2045,41,0.0,0.2,0.2,0.005,0.463,1359,1411,41,1.181,1.000,1414,138.000,105.000,163.012,105.000,1000.0,1299.0,99.0,46.2,31.0,0.0,20.0,1135,122,8.0,29.0,27.0,1.202,11.625,7.375,77.000,85.625,106.500,27.0,29.0,1.001,11.594,2.766,25.750,25.750,31.781,155,7,446.024,15.973,155,7,446.024,15.973,0,
28.5.2016,11:36:20.493,5222,4840,51.8,4118,4024,50.5,0.0,1.199,1.202,1.198,1.198,3899.0,3899.0,3899.0,3899.0,100.0,3899.0,100.0,74.1,66.9,66.1,58.9,74.1,66.5,100.0,No,No,No,No,39,39,39,39,39,No,34,37,33,32,66,63,67,68,37,36,36,26,47.678,37.848,2.235,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,35.0,15.0,26.0,106.0,35.0,1.744,4.968,3.296,3.296,11.808,1.016,1.208,3.472,1.008,1.000,1.104,0.840,0.216,1061,1739,643,1872,No,23,23,No,No,100.0,No,No,2524,2450,2877,6.9,0.0,7.0,4.452,0.005,2054,41,0.0,5.2,5.2,0.000,0.791,1359,1413,43,1.200,1.000,1412,29.000,102.000,34.800,102.000,965.0,1299.0,0.0,55.4,0.0,0.0,20.0,1139,122,8.0,29.0,27.0,1.200,11.625,5.156,35.000,64.375,81.625,27.0,29.0,1.001,11.656,2.703,25.750,25.750,31.688,156,7,472.218,13.446,156,7,472.218,13.446,0,
28.5.2016,11:36:22.652,5245,4818,52.1,4139,4004,50.8,0.0,1.199,1.202,1.198,1.198,3899.0,3899.0,3899.0,3899.0,100.0,3899.0,100.0,59.5,74.2,73.5,65.4,74.2,68.2,100.0,No,No,No,No,39,39,39,39,39,No,30,36,35,35,70,64,65,65,36,35,35,27,48.543,38.375,2.287,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,35.5,15.0,26.0,106.0,35.0,1.744,4.968,3.296,3.280,11.808,1.016,1.208,3.472,1.008,1.008,1.112,0.840,0.216,2125,1735,637,1869,No,23,23,No,No,100.0,No,No,2524,2450,2877,11.8,0.0,11.8,6.313,0.000,2067,41,0.0,0.6,0.6,0.000,1.263,1359,1415,43,1.194,1.000,1413,99.000,104.000,118.181,104.000,991.0,1299.0,74.0,49.2,19.0,0.0,20.0,1140,123,8.0,29.0,28.0,1.194,11.625,5.344,59.000,79.250,95.625,28.0,29.0,1.001,11.625,2.734,26.000,26.000,31.781,157,7,396.085,9.030,157,7,396.085,9.030,0,
28.5.2016,11:36:24.802,5263,4799,52.3,4157,3985,51.0,0.0,1.199,1.202,1.198,1.198,3898.8,3898.8,3898.8,3898.8,100.0,3898.8,100.0,56.1,53.2,67.6,49.6,67.6,56.6,100.0,No,No,No,No,39,39,39,39,39,No,32,32,32,32,68,68,68,68,32,33,33,26,44.818,34.775,2.214,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,33.0,15.0,26.0,106.0,33.0,1.744,4.968,3.296,3.280,11.808,1.008,1.208,3.472,1.008,1.008,1.112,0.840,0.216,1062,1713,640,1869,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.0,0.0,0.024,0.001,2067,41,0.0,0.2,0.2,0.000,0.517,1359,1416,43,1.200,1.000,1412,29.000,102.000,34.800,102.000,965.0,1299.0,0.0,56.1,0.0,0.0,20.0,1142,123,8.0,30.0,28.0,1.200,11.625,8.063,50.500,45.750,72.250,28.0,30.0,1.001,11.625,2.688,25.750,26.000,31.313,158,7,418.950,15.189,158,7,418.950,15.189,0,
28.5.2016,11:36:26.946,5287,4775,52.5,4179,3963,51.3,0.0,1.199,1.202,1.198,1.198,3898.8,3898.8,3898.8,3898.8,100.0,3898.8,100.0,58.3,43.0,59.8,50.3,59.8,52.8,100.0,No,No,No,No,39,39,39,39,39,No,34,35,35,33,66,65,65,67,35,37,37,26,43.757,33.828,2.218,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,35.5,15.0,26.0,106.0,35.0,1.744,4.968,3.296,3.280,11.808,1.016,1.208,3.472,1.008,1.000,1.112,0.840,0.216,1079,1739,637,1869,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.9,0.0,0.9,0.489,0.000,2068,41,0.0,2.8,2.8,0.000,0.931,1359,1418,44,1.200,1.000,1411,30.000,102.000,36.000,102.000,965.0,1299.0,0.0,58.2,0.0,0.0,20.0,1143,123,8.0,30.0,28.0,1.190,11.594,9.469,55.000,48.625,78.250,28.0,30.0,1.001,11.625,2.688,26.000,26.000,31.688,159,7,402.405,13.698,159,7,402.405,13.698,0,
28.5.2016,11:36:29.078,5304,4758,52.7,4196,3946,51.5,0.0,1.199,1.202,1.198,1.198,3898.7,3898.7,3898.7,3898.7,100.0,3898.7,100.0,60.5,66.4,83.2,68.6,83.2,69.7,100.0,No,No,No,No,39,39,39,39,39,No,34,36,36,35,66,64,64,65,36,36,36,27,49.514,39.511,2.400,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,36.5,15.0,26.0,106.0,36.0,1.744,4.968,3.296,3.280,11.808,1.016,1.208,3.472,1.008,1.008,1.112,0.840,0.216,0,1711,642,1869,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.1,0.0,0.1,0.491,0.000,2069,41,0.0,0.2,0.2,0.000,0.436,1359,1419,44,1.200,1.000,1409,38.000,103.000,45.600,103.000,1000.0,1299.0,68.0,55.3,18.0,0.0,20.0,1143,123,8.0,31.0,28.0,1.160,11.625,7.375,72.000,77.000,91.875,28.0,31.0,1.001,11.625,2.734,26.000,25.750,31.406,160,7,406.226,13.122,160,7,406.226,13.122,0,
28.5.2016,11:36:31.221,5328,4734,52.9,4225,3918,51.8,0.0,1.199,1.202,1.198,1.198,3898.7,3898.7,3898.7,3898.7,100.0,3898.7,100.0,59.1,67.1,77.3,62.0,77.3,66.4,100.0,No,No,No,No,39,39,39,39,39,No,35,38,36,33,65,62,64,67,38,36,36,27,48.328,38.337,2.370,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,36.0,15.0,26.0,106.0,36.0,1.744,4.968,3.296,3.280,11.808,1.016,1.208,3.472,1.008,1.008,1.112,0.840,0.216,1066,1735,640,1869,No,23,23,No,No,100.0,No,No,2524,2450,2877,7.4,0.0,7.4,4.406,0.005,2078,41,0.0,0.5,0.5,0.000,1.083,1359,1421,45,1.188,1.000,1411,82.000,103.000,97.375,103.000,1000.0,1299.0,86.0,56.6,21.0,0.0,20.0,1145,123,8.0,31.0,29.0,1.199,11.625,6.594,74.500,95.250,82.375,29.0,31.0,1.001,11.625,2.734,25.750,25.750,31.781,161,7,427.498,9.424,161,7,427.498,9.424,0,
28.5.2016,11:36:33.361,5334,4729,53.0,4236,3907,52.0,0.0,1.199,1.202,1.198,1.198,3898.7,3898.7,3898.7,3898.7,100.0,3898.7,100.0,66.4,67.8,75.9,56.2,75.9,66.6,100.0,No,No,No,No,39,39,39,39,39,No,33,33,35,34,67,67,65,66,35,37,37,27,47.942,37.782,2.296,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,35.0,15.0,26.0,106.0,35.0,1.744,4.968,3.296,3.296,11.904,1.016,1.208,3.472,1.008,1.008,1.112,0.840,0.216,1076,1739,642,1869,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.4,0.0,0.4,1.469,0.000,2081,41,0.1,2.7,2.8,0.036,1.088,1359,1423,45,1.194,1.000,1414,32.000,103.000,38.200,103.000,1000.0,1299.0,92.0,53.0,23.0,0.0,20.0,1146,123,8.0,31.0,29.0,1.139,11.625,7.938,76.500,74.750,56.813,29.0,31.0,1.001,11.625,2.734,25.750,25.750,31.781,161,7,405.690,17.335,161,7,405.690,17.335,0,
28.5.2016,11:36:35.497,5338,4724,53.0,4236,3906,52.0,0.0,1.199,1.202,1.198,1.198,3898.7,3898.7,3898.7,3898.7,100.0,3898.7,100.0,61.3,71.5,75.9,60.5,75.9,67.3,100.0,No,No,No,No,39,39,39,39,39,No,35,37,36,35,65,63,64,65,37,36,36,28,48.563,38.454,2.343,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,37.0,15.0,26.0,105.0,37.0,1.744,4.968,3.296,3.280,11.808,1.016,1.208,3.472,1.008,1.008,1.112,0.840,0.216,1062,1719,642,1872,No,23,23,No,No,100.0,No,No,2524,2450,2877,2.0,0.0,2.0,1.472,0.000,2084,41,0.0,0.3,0.3,0.000,0.806,1359,1425,45,1.206,1.000,1412,79.000,104.000,95.294,104.000,991.0,1299.0,94.0,53.8,20.0,0.0,20.0,1149,123,8.0,31.0,29.0,1.188,11.625,6.125,60.500,82.250,86.375,29.0,31.0,1.001,11.594,2.734,26.000,26.000,31.781,163,7,643.926,15.212,163,7,643.926,15.212,0,
28.5.2016,11:36:37.640,5347,4716,53.1,4246,3896,52.1,0.0,1.199,1.202,1.198,1.198,3899.1,3899.1,3899.1,3899.1,100.0,3899.1,100.0,72.7,68.3,85.2,65.4,85.2,72.9,100.0,No,No,No,No,39,39,39,39,39,No,33,37,37,35,67,63,63,65,37,39,39,28,50.461,40.455,2.416,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,37.0,15.0,26.0,106.0,37.0,1.744,4.968,3.312,3.296,11.904,1.016,1.208,3.472,1.008,1.000,1.112,0.840,0.216,1077,1735,643,1872,No,23,23,No,No,100.0,No,No,2524,2450,2877,13.3,0.0,13.3,9.792,0.000,2104,41,0.0,2.6,2.6,0.000,1.269,1359,1428,45,1.194,1.000,1410,117.000,106.000,139.669,106.000,1000.0,1299.0,49.0,56.0,9.0,0.0,20.0,1150,123,8.0,32.0,29.0,1.205,11.625,7.688,69.500,86.750,101.250,29.0,32.0,1.001,11.625,2.734,26.000,25.750,31.781,164,7,372.191,9.712,164,7,372.191,9.712,0,
28.5.2016,11:36:39.782,5348,4715,53.1,4244,3898,52.1,0.0,1.199,1.202,1.198,1.198,3899.1,3899.1,3899.1,3899.1,100.0,3899.1,100.0,70.2,71.0,78.9,64.4,78.9,71.1,100.0,No,No,No,No,39,39,39,39,39,No,32,38,38,35,68,62,62,65,38,36,36,28,50.503,40.477,2.430,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,37.0,15.0,26.0,106.0,37.0,1.744,4.968,3.296,3.280,11.904,1.016,1.208,3.472,1.008,1.008,1.112,0.840,0.216,2122,1739,643,1872,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.7,0.0,0.7,0.489,0.000,2105,41,0.0,0.2,0.2,0.000,0.563,1359,1429,46,1.194,1.000,1409,120.000,106.000,143.250,106.000,1000.0,1299.0,38.0,69.0,5.0,0.0,20.0,1150,123,8.0,32.0,29.0,1.208,11.625,6.938,65.000,90.000,89.625,29.0,32.0,1.001,11.594,2.734,26.000,25.750,31.406,164,7,294.863,10.332,164,7,294.863,10.332,0,
28.5.2016,11:36:41.913,5348,4714,53.1,4244,3899,52.1,0.0,1.199,1.202,1.198,1.198,3898.7,3898.7,3898.7,3898.7,100.0,3898.7,100.0,70.0,72.9,81.7,60.5,81.7,71.3,100.0,No,No,No,No,39,39,39,39,39,No,35,39,37,35,65,61,63,65,39,36,36,27,51.046,41.042,2.465,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,37.5,15.0,26.0,105.0,37.0,1.744,4.968,3.296,3.280,11.904,1.016,1.208,3.472,1.008,1.008,1.112,0.840,0.216,1066,1735,639,1869,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.0,0.0,0.000,0.000,2105,41,0.0,5.9,5.9,0.000,0.784,1359,1430,46,1.200,1.000,1413,127.000,106.000,152.400,106.000,991.0,1299.0,85.0,58.1,21.0,0.0,20.0,1150,123,8.0,32.0,30.0,1.184,11.594,7.969,49.500,83.875,93.000,30.0,32.0,1.001,11.625,2.734,26.000,26.250,31.688,165,7,323.284,12.021,165,7,323.284,12.021,0,
28.5.2016,11:36:44.057,5352,4710,53.1,4249,3893,52.1,0.0,1.199,1.202,1.198,1.198,3898.7,3898.7,3898.7,3898.7,100.0,3898.7,100.0,72.7,63.2,83.0,63.2,83.0,70.5,100.0,No,No,No,No,39,39,39,39,39,No,34,39,36,34,66,61,64,66,39,36,36,28,50.692,40.673,2.407,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,37.0,15.0,26.0,106.0,37.0,1.744,4.968,3.296,3.280,11.808,1.016,1.208,3.472,1.016,1.008,1.112,0.840,0.216,1052,1713,639,1872,No,23,23,No,No,100.0,No,No,2524,2450,2877,1.1,0.0,1.1,0.489,0.000,2106,41,0.0,0.1,0.1,0.000,0.148,1359,1431,47,1.200,1.000,1411,37.000,103.000,44.400,103.000,1000.0,1299.0,91.0,65.2,23.0,0.0,20.0,1153,123,8.0,33.0,30.0,1.189,11.625,4.906,66.500,89.625,100.250,30.0,33.0,1.001,11.594,2.734,26.000,26.000,31.781,166,7,409.538,10.143,166,7,409.538,10.143,0,
28.5.2016,11:36:46.208,5354,4708,53.2,4248,3895,52.1,0.0,1.199,1.202,1.198,1.198,3898.7,3898.7,3898.7,3898.7,100.0,3898.7,100.0,62.3,68.1,81.1,56.5,81.1,67.0,100.0,No,No,No,No,39,39,39,39,39,No,33,33,34,33,67,67,66,67,34,34,34,28,49.196,39.154,2.334,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,36.0,15.0,26.0,106.0,36.0,1.744,4.968,3.296,3.280,11.808,1.016,1.208,3.472,1.008,1.008,1.112,0.840,0.216,1067,1741,642,1872,No,23,23,No,No,100.0,No,No,2524,2450,2877,1.0,0.0,1.0,0.487,0.000,2107,41,0.0,2.5,2.5,0.000,0.699,1359,1432,47,1.181,1.000,1410,75.000,104.000,88.594,104.000,1000.0,1299.0,91.0,56.9,19.0,0.0,20.0,1155,123,8.0,33.0,30.0,1.194,11.625,9.094,74.500,62.125,48.750,30.0,33.0,1.001,11.656,2.766,26.000,25.750,31.500,166,7,289.059,15.821,166,7,289.059,15.821,0,
28.5.2016,11:36:48.352,5360,4702,53.2,4254,3889,52.2,0.0,1.199,1.202,1.198,1.198,3898.7,3898.7,3898.7,3898.7,100.0,3898.7,100.0,56.9,59.1,67.8,62.7,67.8,61.6,100.0,No,No,No,No,39,39,39,39,39,No,32,29,37,35,68,71,63,65,37,32,32,28,45.434,35.513,2.211,799.7,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,36.0,15.0,26.0,106.0,36.0,1.760,4.992,3.312,3.312,11.904,1.008,0.768,3.472,1.016,1.008,1.112,0.840,0.216,1053,1735,637,1869,No,23,23,No,No,100.0,No,No,2524,2450,2877,1.6,0.0,1.6,0.009,0.000,2107,41,0.0,0.5,0.5,0.000,0.946,1359,1434,45,1.144,1.000,1411,100.000,105.000,114.375,105.000,699.0,1299.0,94.0,30.4,30.0,0.0,20.0,1155,123,8.0,33.0,30.0,1.194,11.625,5.719,50.000,67.375,79.125,30.0,33.0,1.001,11.625,2.734,26.250,26.000,31.781,168,7,718.136,27.465,168,7,718.136,27.465,0,
28.5.2016,11:36:50.496,5376,4687,53.4,4273,3869,52.4,0.0,1.199,1.202,1.198,1.198,3899.0,3899.0,3899.0,3899.0,100.0,3899.0,100.0,44.5,24.8,50.3,51.8,51.8,42.8,100.0,No,No,No,No,39,39,39,39,39,No,27,26,28,38,73,74,72,62,38,33,33,27,38.062,28.605,2.033,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,36.0,15.0,26.0,106.0,36.0,1.760,4.992,3.312,3.312,11.904,1.016,1.160,3.472,1.008,1.008,1.112,0.840,0.216,2125,1726,640,1882,No,23,23,No,No,100.0,No,No,2524,2450,2877,2.5,0.0,2.5,0.986,0.000,2109,41,0.0,0.2,0.2,0.000,0.492,1359,1435,42,0.988,1.000,1415,8.000,7.000,7.900,7.000,300.0,149.5,0.0,0.0,1.0,0.0,20.0,1155,123,2.5,33.0,30.0,0.988,11.688,0.625,8.000,7.906,7.281,30.0,33.0,1.001,11.688,0.156,1.750,1.750,1.813,170,7,918.989,28.662,170,7,918.989,28.662,0,
28.5.2016,11:36:52.628,5381,4682,53.4,4257,3886,52.2,0.0,1.199,1.202,1.198,1.198,3899.0,3899.0,3899.0,3899.0,100.0,3899.0,100.0,31.3,18.9,18.9,29.1,31.3,24.5,100.0,No,No,No,No,39,39,39,39,39,No,30,31,32,33,70,69,68,67,33,32,32,28,33.247,23.111,1.638,799.8,8.00,11,11,11,28,208,1,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,No,24.0,32.5,15.0,26.0,106.0,32.0,1.744,4.968,3.296,3.296,11.808,1.016,1.208,3.472,1.008,1.000,1.104,0.840,0.216,0,1713,644,1875,No,23,23,No,No,100.0,No,No,2524,2450,2877,0.0,0.0,0.0,0.000,0.000,2109,41,0.1,2.2,2.2,0.002,0.573,1359,1436,44,0.988,1.000,1414,12.000,102.000,11.850,102.000,300.0,1299.0,0.0,0.0,0.0,0.0,20.0,1132,122,2.5,33.0,30.0,0.986,11.688,0.781,10.000,9.844,9.125,30.0,33.0,1.001,11.688,2.688,25.500,25.500,31.406,171,7,525.913,24.046,171,7,525.913,24.046,0,
