PC components help please
dead_mentor
121
Hello, i have decided in building a PC, and here are the current specs
GPU: EVGA GeForce GTX1070 SC Gaming ACX 3.0 8GB GDDR5
CPU: Intel Core i7 7700K
Motherboard: MSI Z270-A PRO
Can anyone tell me if that motherboard will be able to fit those components?
and also, can you recommend me a memory RAM that works with it ? (it doesnt have to be expensive memory ram's, DDR4)
Will these RAM work for that motherboard, for example:
Crucial 8GB Value DDR4 2133MHz PC4-17000 CL15 - CT8G4DFD8213
or
Crucial 16GB DDR4 2133MHz PC4-17000 CL16 - CT16G4DFD8213
or
Crucial 16GB DDR4 2133MHz PC4-17000 CL15 - CT16G4SFD8213
Thanks in advance
voodoobunny
108
I would recommend seeing if faster memory is available for not-too-much more - it won't make a huge difference, if (say) DDR4-3200 is only a few dollars more than DDR4-2133, you should definitely consider it.
