Hey guys
I'm Using a Canyon Pc controller to only play Fifa 15. The RS is used for skill moves and the LS just for normal dribbling. So for some reason The RS started causing real problems. Whenever i play fifa it's like the RS is being used all the time but i'm not touching it. It's very annoying because i can't dribble normal because whenever i get the ball my player just tries to skill all the time and it makes me unable to play.. when i press the analog key off i can dribble normal with the arrows(the alternative moving buttons) but it's difficult to play fifa that way and i want to use the LS but whenever i put the analog key on it enables the LS and RS and the RS makes it impossible to play. So i don't care about ever using the RS so how can i disable it?
