Hi All,
Had my rig for many years 5+ worked fine.
Noticed sluggish behavior over past months. PC will now crash anytime loading a game or even occasional loading video. (PC powers off)
Typically needs to hard reset mobo to get it to restart.
Have tried removing/ swapping ram, but same result. Also cleaned the PC of dust etc.. it was a bit overdue XD.
PC does restart fine when GPU is removed after a crash. Has not crashed without the GPU but have not stress tested. Oh and Bios is all default.
Have scanned forums for days, finally posting. Please help!
Spec:
OS: Windows 7 64bit
Mobo: Asus M4A88TD-V
GPU: Msi Geforce 560 gtx Ti
CPU: AMD Athlon II X4 640. 3.00 Ghz
PSU: (just replaced thought this would fix it) EVGA 500W Bronze
Ram: Crucial (pairs of 2GB) usually run 2 pairs. 1033.
Thank you for any advice!
Spec:
OS: Windows 7 64bit
