pc crashes daily, not sure how to troubleshoot; help!
Aug 14, 2018
14
pc crashes daily, not sure how to troubleshoot. This is totally menacing. I built this system myself about 3 years ago. I know enough to spec and build a system, but not enough to know how to troubleshoot and fix the issue I am having.
Basically, my system boots into Windows with no problem. However, it crashes and reboots itself on an almost daily basis. Please help in troubleshooting this for me! I suspect it may be a bad motherboard, but I really do not know.
I've run memtest and got no errors therefrom. That's about as far as I've gone. Any help is greatly appreciated!! Here are the specs from Speccy:
Operating System
Windows 7 Home Premium 64-bit SP1
CPU
Intel Core i5 4670K @ 3.40GHz 30 °C
Haswell 22nm Technology
RAM
8.00GB Dual-Channel DDR3 @ 798MHz (11-11-11-28)
Motherboard
Gigabyte Technology Co. Ltd. H87-D3H-CF (SOCKET 0) 28 °C
Graphics
VS24A (1920x1200@59Hz)
Intel HD Graphics 4600 (Gigabyte)
Storage
232GB Samsung SSD 840 EVO 250G SCSI Disk Device (SSD) 27 °C
1863GB Western Digital WDC WD20EZRZ-00Z5HB0 SCSI Disk Device (SATA) 25 °C
Optical Drives
ATAPI iHAS124 W SCSI CdRom Device
Audio
Realtek High Definition Audio
Aug 14, 2018
14
I just went through that checklist. I changed the BIOS to XMP memory enabled. We'll see if that makes any difference. Thanks for the link! Oh, and I ordered a system speaker which I currently do not have.
Aug 14, 2018
14
Still trying to troubleshoot this issue without having to reinstall windows. This is the latest I've come up with:
https://social.technet.microsoft.com/Forums/windows/en-US/4d74523f-2b9e-4fe7-9b5e-f0153166adcc/hibernation-fails-after-installation-of-sp-1?forum=itprovistasp
1. Run CMD.EXE as administrator
2. Run the following command: bcdedit -enum all
Look for "Resume from Hibernate" in the output from the command above(example below):
identifier {3d8d3081-33ac-11dc-9a41-806e6f6e6963}
device partition=C:
path \Windows\system32\winresume.exe
description Windows Vista (TM) Enterprise (recovered)
inherit {resumeloadersettings}
filedevice partition=C:
filepath \hiberfil.sys
pae Yes
debugoptionenabled No
3. Once you have found it, copy the value for identifier (in this example - {3d8d3081-33ac-11dc-9a41-806e6f6e6963})
4. Run the following command: bcdedit /deletevalue {3d8d3081-33ac-11dc-9a41-806e6f6e6963} inherit
5. Test hibernation.
Initial tests are successful. We'll see what happens over some time.
Yea, I saw that that error was power related. As a side note, SSD's really do not need to go to sleep. Just lock the unit and unlock when needed. That is what I do. Keep me posted.
Aug 14, 2018
14
Without getting into the LONG details. I believe my RAM is bad. Strange thing is the RAM did pass MEMTEST. So either I am wrong, or MEMTEST is wrong. Not sure which.
(I put the RAM in a system that was rock stable. That RAM gave the previously rock stable system BSOD's so bad the OS wouldn't load. Put the old RAM back in and the system was fine again. Not sure if BIOS had anything to do with it, but I doubt it.)
