Question PC crashes randomly and gets stuck on the EZDebug VGA light ? Please help
5
PC Specs
MSI X570 Gaming Edge WiFi MotherboardAMD Ryzen 5 3600XCrucial P1 M.2 NVMe SSD 500GB (C Drive)Seagate Barracuda 2TB ST2000DM008 3.5in Hard DriveG.Skill Trident Z RGB 16GB (2x8GB) 3600MHz CL16 DDR4Corsair RM750x Gold Modular 750W Power SupplyPowerColor Radeon RX 6700 XT Red Devil OC 12GB RDNA 2
My PC has been working fine for the past year with no issues and then all of a sudden my PC started to crash randomly when I was playing FFXIV. When I did crash the screen would freeze, then go black and all of the lights on PC would still and it would try to boot but get on the VGA Ezdebug light. After a day it started to crash even at the desktop. I removed one of a RAM sticks and then stress tested the PC and it crashed after like a minute and swapped it with the other stick and it worked fine for hours with no issue. But even after I've done that it isn't crashing that much instead of every 10 min its once every 10 hours + so I'm sure if it is the this single stick as well. Isn't the RAM tested with new RAM sticks.
I have tried the following:
  • Clearing CMOS and removing the battery
  • Removing and reconnecting all power cable connection
  • making sure all software is up to date.
  • rolled back updates to ones that I know work
  • Stress tested PC and with the working stick for 4 hours and no issue
  • Bought 2 new stick's of ram and put them in the PC and the issue still happened
  • Also heat isn't an issue as far as I'm aware
I'm out of ideas please help, also sorry for my bad English
