Question PC Crashing. Is there a more efficient way to diagnose the issue?
Feb 10, 2025
4
Specs
GPU: EVGA RTX 3080 XC3 Ultra Gaming (2020)
CPU: Ryzen 7 5800x (2021)
Cooler: Arctic Liquid Freezer II 280 AIO (2020)
MOBO: ASUS ROG X570 Crosshair VIII Hero WiFi. (2021)
RAM: 2x8GB G.Skill TridentZ RGB DDR4-3200 14 CAS (2020)
PSU: ASUS ROG Strix 750w 80 Plus Gold (2022)
Windows Drive: 2TB: Crucial MX500 SSD (2019)
HDD: Seagate Barracuda 4TB 5400RPM (2021)
Monitor 1: Acer Predator XB271HU bmiprz 27" 1440p 144hz. (2019)
Monitor 2: LG 27UL500-W 27" 4K 60hz (2019)
OS: Windows 10
Previously had windows installed on Sabrent 1TB rocket NVMe m.2 drive. (2020)
Previously used a Seasonic Focus+ 750W (2019)
Giving a full rundown of the issues with this damn thing the last few years. In November 2022 I started getting hard crashes where the PC would restart itself. No bluescreen that I could see and there were no Minidumps being created. I ended up buying a PSU replacement and that seemed to fix everything for a time. Then in March of this past year I started having issues with crashing again. This time at least involving a BSOD. Still no Minidump files. Saw people saying that it could be a failing m.2 drive so I experimented and did a clean install of windows onto the M.2 that I had been using as my boot drive for a long time. Crashes continued. Removed the m.2 and did a clean install onto my SSD and the crashes stopped. So I bought a new m.2 but I've been too lazy to actually do another clean windows install and plug in the new m.2.
Now, in the last couple of weeks I've been having issues with my PC crashing while gaming again. Screens go black, sound keeps going for a few seconds before cutting out and the PC restarts. It's at least generating minidumps now which you can see below. I've only run 2 through windowsdbg, but they both said pretty much the same thing. Video TDR Failure. When I played Skyrim on it, it was mostly fine. It crashed a couple of times when I had it running in fullscreen borderless window at 4k. But it ran fullscreen 4K just fine as well as fullscreen or borderless window on my 1440p monitor. Hell Let Loose wouldn't even make it to the main menu before crashing. Alien Isolation would crash within 5 minutes or so of playing. 3D Mark Timespy Extreme would cause a crash as soon as I hit run test.
I tried re-seating the GPU and everything worked flawlessly after that. I was able to play several hours of Alien and finish out that game. I got through a whole match on Hell Let Loose. Ran a full 20 loops on Timespy Extreme without issue. Bought Kingdom Come Deliverance and played for an hour or so without issue. I paused the game and stepped away for a while and came back a little later. The monitors had gone to sleep so I jiggled the mouse and put my headphones on. There was still sound coming through from the game. The monitors didn't seem to wake up and then after a few seconds the sound cut out in the headset and my PC restarted itself. I launched the game again and made it about 5 or 10 minutes before it black screened and restarted again. Tried to do a full shut down and start up instead of just a restart to see if that would do anything. Then the game wouldn't even make it to the main menu before crashing.
I'm gonna try and do a clean install of windows tonight and see what that does. If it's still causing issues I've got a friend who offered to bring over his 2070 Super to test out. I'm at a loss though. Is there really no way to figure out if this is a software or hardware issue (as well as which piece of hardware is at fault) beyond just swapping out parts to see if one fails? Not to mention based off the previous scenario of gaming just fine for days and then regressing back to having crashing issues - makes it impossible to know if borrowing my friend's GPU for a few hours will tell me anything.
Is it normal to have this many issues over just 3 years with a PC. This feels insane.
* Bugcheck Analysis *
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: ffff800f6b750010, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff80398a7f690, The pointer into responsible device driver module (e.g. owner tag).
Arg3: ffffffffc000009a, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000004, Optional internal context dependent data.
Debugging Details:
Unable to load image \SystemRoot\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_1e8724cced6e93d4\nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1250
Key : Analysis.Elapsed.mSec
Value: 2506
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 3
Key : Analysis.Init.CPU.mSec
Value: 265
Key : Analysis.Init.Elapsed.mSec
Value: 18742
Key : Analysis.Memory.CommitPeak.Mb
Value: 160
Key : Analysis.Version.DbgEng
Value: 10.0.27725.1000
Key : Analysis.Version.Description
Value: 10.2408.27.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2408.27.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x116
Key : Bugcheck.Code.TargetModel
Value: 0x116
Key : Failure.Bucket
Value: 0x116_IMAGE_nvlddmkm.sys
Key : Failure.Hash
Value: {c89bfe8c-ed39-f658-ef27-f2898997fdbd}
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Version
Value: 10.0.19041.1
BUGCHECK_CODE: 116
BUGCHECK_P1: ffff800f6b750010
BUGCHECK_P2: fffff80398a7f690
BUGCHECK_P3: ffffffffc000009a
BUGCHECK_P4: 4
FILE_IN_CAB: 020325-12687-01.dmp
FAULTING_THREAD: ffff800f643265c0
VIDEO_TDR_CONTEXT: dt dxgkrnl!_TDR_RECOVERY_CONTEXT ffff800f6b750010
Symbol dxgkrnl!_TDR_RECOVERY_CONTEXT not found.
PROCESS_OBJECT: 0000000000000004
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
STACK_TEXT:
fffff98a`9d6479d8 fffff803`7e6668de : 00000000`00000116 ffff800f`6b750010 fffff803`98a7f690 ffffffff`c000009a : nt!KeBugCheckEx
fffff98a`9d6479e0 fffff803`7e616fa4 : fffff803`98a7f690 ffff800f`68b02720 00000000`00002000 ffff800f`68b027e0 : dxgkrnl!TdrBugcheckOnTimeout+0xfe
fffff98a`9d647a20 fffff803`7e60fadc : ffff800f`68adb000 00000000`01000000 00000000`00000004 00000000`00000004 : dxgkrnl!ADAPTER_RENDER::Reset+0x174
fffff98a`9d647a50 fffff803`7e666005 : 00000000`00000100 ffff800f`68adba70 00000000`63a4e700 fffff803`70ab499c : dxgkrnl!DXGADAPTER::Reset+0x4dc
fffff98a`9d647ad0 fffff803`7e666177 : fffff803`71525440 ffff800f`6a131d70 00000000`00000000 00000000`00000100 : dxgkrnl!TdrResetFromTimeout+0x15
fffff98a`9d647b00 fffff803`70a171c5 : ffff800f`643265c0 fffff803`7e666150 ffff800f`5a69e980 ffff800f`00000000 : dxgkrnl!TdrResetFromTimeoutWorkItem+0x27
fffff98a`9d647b30 fffff803`70b5a165 : ffff800f`643265c0 00000000`00000080 ffff800f`5a6be200 000fe067`b4bbbdff : nt!ExpWorkerThread+0x105
fffff98a`9d647bd0 fffff803`70c078f8 : fffff803`6ba51180 ffff800f`643265c0 fffff803`70b5a110 04d172e8`8f1a54c8 : nt!PspSystemThreadStartup+0x55
fffff98a`9d647c20 00000000`00000000 : fffff98a`9d648000 fffff98a`9d641000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x28
SYMBOL_NAME: nvlddmkm+184f690
MODULE_NAME: nvlddmkm
IMAGE_NAME: nvlddmkm.sys
STACK_COMMAND: .process /r /p 0xffff800f5a6be200; .thread 0xffff800f643265c0 ; kb
FAILURE_BUCKET_ID: 0x116_IMAGE_nvlddmkm.sys
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {c89bfe8c-ed39-f658-ef27-f2898997fdbd}
Followup: MachineOwner
People who owned a RTX3080 were advised to go for a reliably built PSU that was at least 850W or 1KW to offset the transient load spikes of the GPU.
What BIOS version are you on for your motherboard?
As for the clean install of the OS, recreate the bootable USB installer, disconnect all drives except for the one you wish to install the OS onto, install the OS in offline mode, then install all necessary drivers in an elevated command, i.e, Right click installer>Run as Administrator.
As it stands, you can try and use DDU in Safe Mode, to remove all GPU drivers(intel, AMD and Nvidia), then manually install the latest GPU driver sourced from Nvidia's support site, in an elevated command.
Sorry worth mentioning that I’ve run DDU a couple of times already. I can certainly always give it another try. My bios is whatever the bios was most current in November of 2022 for my board. Before I replaced the PSU, I updated it to try it out.
Does it do that only for games (and GPU benchmarks)? What happens if you run Cinebench or Prime95?
I tried Prime95 a couple years ago before resolving issues with the new PSU. Had no issues running it then though. Haven't run it since, but surely it wouldn’t be CPU related if it’s giving me video TDR errors right?
It cost nothing to try again just to make sure your system is stable. The bug report says that your system could not load the driver image. Could be a CPU error, a corrupted file, a GPU problem, etc. so better to rule out system instability with an easy and quick test (just let prime running for like 10 minutes).
Does it systematically generate the same bug report when it crashes (with the same error)? Did you try to reinstall Windows like you said you would do in your OP?
Ran Prime95 for a little over 10 minutes and everything was fine. I borrowed a friends 2070 Super, but as it turns out his card is massive and won't fit in my case. I reinstalled windows (this time to the m.2 drive that I bought nearly a year ago and never installed to replace my previous one) and crashing persisted, but now it's not generating a mini dump. The not creating a mini dump is something that I had encountered in previous issues with my pc.
I was able to run stress tests in 3D Mark for Steel Nomad and Timespy extreme. Ran 20 loops in each with no issues.
I may have made a mistake in installing windows to the m.2. I had previously had two separate issues with crashing as mentioned in my original post. The first one was resolved by replacing the PSU and the second one was resolved by removing my m.2 drive and installing windows on my SSD. I had bought a new m.2 after that more recent issue, but never took the time to install it. I figured since I was reinstalling windows it might be as good a time as any to install the newer m.2 as well. Is there anyway to figure out if the m.2 slot itself is what is causing that issue?
I guess I can remove the m.2 again and do another clean windows install back onto the SSD to see what it does, but now I feel like I'm going crazy. Is my issue my GPU, windows, my motherboard, or my PSU? At this point would it be easier to just take it to a repair shop so they can tell me what the issue is? Short of buying a whole new computer piecemeal to figure out which part is the culprit, I'm running out of options.
Updating this thread. I went out and got a 1000w Corsair RMx PSU from BestBuy just to test it out and see what my PC did with an overkill PSU. Figured that if crashing continued then I could just put everything back in the box and return it, but I could at least cross one piece of hardware off the list of potential culprits. Played on it last night for a few hours and no crashes. Fingers crossed that it was just the PSU again. Is it possible that my 3080 just wore out those 750w PSUs over a couple of years until they could no longer handle the transient spikes in power that the 3000 series is known for? It just seems odd to me that everything ran fine for about 2 years on the Seasonic Focus+ and then it went to shit. Ran fine on the ASUS ROG Strix for about 2 years and went to shit again. Is wearing down on the PSU like that a thing?
Going to keep testing it out to see if it continues to run without crashes. I've already had that one scenario where everything ran fine for several hours of gaming giving me hope only for it to start crashing again so the cup is still in place awaiting the kick to the nuts.
A power supply is one of those components that will tend to age and not always be able to power components. From what I can see, Nvidia required a 750 watt power supply. But at that point, in my opinion, yes it should work, but you may be pushing close to what the PSU can do.
For example, when I got my 7900xtx last year, even though it requires an 800 watt unit and I had an 850 watt psu, I went ahead and upgraded to a 1200 watt unit. I was going for a 1000 watt unit originally, but Newegg had a tier A rated 1200 watt Thermaltake unit for not much more than the other ones I looked at. So myself, personally, I like to upsize the power supply a little. For one as I said, you know they will age and not always be able to deliver the same amount of power, especially if you are pushing them towards the top of their range. Plus if you go a little higher on power supply then it should handle upgrades you want to do later. Might be worth looking at the warranty on the other PSU you had and get an RMA for it to get another one then you can either have a spare, or if they send you a new one, you can sell it or something.
