PC crashing when booting, then booting again and nothing is wrong?
tim641
Commendable
Jun 21, 2016
34
So 3 days ago i played GTA V and my pc completely crashed. Since that happened, when i boot my PC and it starts loading into windows it shuts itself off. i wait 30 seconds, boot it again, and it works perfectly fine. Is this a faulty SSD or PSU?
I have 2 year warranty (i let some dutch company build my PC) and i can bring it to them to get it fixed (and parts replaced for free) but it will take a week. do you guys think its something that will fix itself eventually or should i just bring my pc to them?
Sorry, totally forgot about that. specs:
MSI GTX 1070 Gaming X
i7 6700k
MSI z170a Gaming M5
2x8GB ddr4 Ram
nzxt s340 razer edition case
corsair rm750x PSU
MSI Core Frozr L cooler
Its a pretty big company, they probably get ALOT of PC's to fix and build. a week is pretty damn long though
It did work fine for the past 3 days after booting it up after it failed, but i was playing some csgo 10 minutes ago, and got a bluescreen. The error said: bad_pool_header. Im not sure what it means
have you tried reinstalling your GPU driver? it's possible that there is a program you're using that can be causing that too. i had a very similar problem a while back and found that uninstalling MSI afterburner fixed it for me. not saying that'll work for you, though. have you checked out the windows crash reports?
I didnt reinstall them yet, but can bad drivers cause the pc to turn off when booting? Ive been using these drivers for like 2 weeks without problems. I didnt turn the pc back on after the bsod in case something is wrong with my PSU, i guess ill just bring my pc to the shop tommorow to let them fix it
