My new PC was working fine, and while waiting for an install to complete (so the PC was on) I touched a led strip.
The PC shut off immediately (no smoke or anything) and now remains completely dead.
If I switch it on, nothing happens: no working fans not even on PSU, no leds anywhere, no clicking sound from the HDD (OS is on SSD though).
I checked:
What to do?
I am thinking of replacing the PSU, and if that doesn fix it I will replace the motherboard (reluctanty because of the OS license issue that will arise).
Any better thoughts? Is the PSU still a suspect after that paperclip test? Did I overlook something?
I7-9700F, MSI MAG Z390 Tomahawk, 750 Watt Cooler Master, NVIDIA RTX 2070 SUPER 8GB,
Crucial 16GB ValueRAM DDR4-2666, Cooler Master ML120R RGB water cooling, SSD 500GB Crucial MX500, HDD 3000GB SATA III
I checked:
- the power cord
- the switch on the PSU , '1' is pressed
- I looked at and pressed power cables on motherboard
- The PSU passes the paperclip test: its fan spins up
- I did shortcut the cmos pins for 10 sec for a reset of the CMOS on the motherboard
What to do?
