Hi,
So I have turned my PC off and went to sleep like I do everyday, but the next day, I push the power button, I get a BIOS message that all settings were reset to default, and then Windows gave BSOD while booting, this ONLY happened first time. Then when I restarted it, the CPU fan starts and the lights turn on, but there is no POST, the monitor stays black, the keyboard and mouse do not turn on, and it stays like this forever. Then this kept on happening each time when I turn the PC on. Speaker does not beep.
My specs:
- Motherboard: MSI 970A-G46
- CPU: AMD FX 6300 (No OC, HyperEVO 212 cooler)
- RAM: 4GB Kingston DDR3
- GPU: AMD Radeon HD 7750 (No OC)
- PSU: Huntkey GreenPower 550W (Had it for almost 4 years)
What I have tried:
1- Reset CMOS (Using Jumper and Battery Removal).
2- Swap RAM slots.
3- Getting CPU out and then placing it in again.
4- Trying another GPU (Nvidia Geforce 8400GS)
5- Disassemble everything and assembling them back again. (PSU cables, mouse, keyboard, etc...)
6- Discharging PSU capacitors using 30-second power button holding.
7- Using vacuum to clean the components.
8- CMOS Battery gives full 3V when testing it using a multimeter.
Maybe two times while desperately powering off and on, it turned on, but I got a message from the BIOS that all settings were reset to default, Windows gave a BSOD and then halted, the second time this happened, Linux worked flawlessly. In both times, turning the PC off wont make it turn on again.
I am desperate, if anyone solves this, I wont hesitate to select it as best answer as soon as possible.
My specs:
What I have tried:
2- Swap RAM slots.
