ASUS TUF GAMING B550-PLUS - AMD B550
AMD Ryzen 5 3600
Kingston A2000, M.2 - 1TB
Seasonic Focus Gold 750 - 750W
Fractal Design Define R5, titanium
Arctic Freezer 34
HyperX Fury Black 32GB (2x16GB) DDR4 3200, black
NVIDITA GTX 1050Ti (it is from my old PC and it works there)
This is a problem that I am facing:
When I start PC then the green error lights on the motherboard keep light up.
this is the flow of the lights on the motherboard:
Orange turns on and after the moment is off. Then Red is on and after the moment is off. Then White on and then off. Green on and keep lighting up.
The monitor is not turned on. I tried to remove RAM and put them into the different slots (single RAM into each slot and I tried both modules)
FAN on the CPU is spinning, also both FANs in the case are spinning.
Graphic FAN start spinning but after the green led turned ON then the FAN on the graphic is stop spinning
ATX 8pin and ATX 24pin are plugged in.
Any idea about what to try?
AMD Ryzen 5 3600
Arctic Freezer 34
