New build, and everything is fine with a cold boot. Absolutely no issues in Windows. If I restart (or shutdown), either from Windows or from the BIOS by saving a setting, the system hangs and does not POST. In order to boot I will have to switch off the power supply for a few seconds and then turn it back on. Thankfully everything then picks up where it left off, so BIOS settings/flashing will save and Windows updates will continue.
I do not currently have a motherboard speaker, but this article about the Power LED indicates a VGA error as I get the flashing every two seconds: https://www.asus.com/support/FAQ/1046157 I also tried booting without RAM and get the 4 per second flashing, so it seems to be accurate information... but I'll confirm with the beeps once the speaker gets here. But even assuming that is correct I am still at the end of my rope.
I feel like it either had to be a defective motherboard, or a simple setting in the BIOS somewhere that I've never heard of. Power save/something not ramping up after a restart and blaming the GPU? Any thoughts?
- Other similar-ish threads mention this could be Power Supply. I swapped a different one in and it did not help.
- I completely removed the GPU (old 1080) and used the onboard graphics, no change. I thought maybe it was switching from the GPU to onboard after the restarts (and something was maybe wrong with the 12900K CPU/iGPU), but onboard works fine and has the same problem.
- Ran Memory Diagnostics and swapped out sticks just to eliminate the possibility of a RAM issue.
- Toggled CSM on/off and disconnected all drives (since it happens from BIOS I don't even need a boot/any drive to test... just save a setting to restart). No change.
- Disabled Fast Boot/MCE, BIOS is latest version 1601.
