PC does not want to display. No cursor. Press keyboard caps lock and light doesn't show.
IeoIeo
Commendable
May 18, 2016
5
Rma'd this motherboard because the display stopped working. The keyboard LED would light up for a second then stop and the mouse had the CPI led button lit the whole time on red for default. That all happened after a Windows 10 system update. Well I got my new motherboard yesterday, set it all up and it worked! First I booted it up with no hard drive or SSD. I added them for a second boot and hey it worked! Made it to the main screen with the task bar. I noticed the front fan didn't work so I shut it down to fix that and when I did the problem came back... Don't know what to do about this. Any idea? I have a weird feeling that somehow the hard drive is messing my motherboards up. :??:
edit: Oh yeah forgot to mention cause maybe this might help but no BIOS at all at start up either.
This has been something I did before with the old motherboard. I tried it again just now. Took out GPU, reseated RAM and reset CMOS but still nothing. I can't do anything with the keyboard and mouse because it's like they have no input either...
Well really all I did for the fan was plug the connectors together tighter and that's what fixed it. I guess if they get slightly tugged it just doesn't work.
But I get the feeling the computer just killed the MOBO again.
