Hello! I Just started building a new pc, but open trying to turn it on, a quiet high pitch wheeze comes from my psu and nothing comes on. (no lights, no fans, nothing) I then started to trouble shoot, as I did that I noticed that the PC only turns on when the CPU power cable is unplugged, it doesn’t matter if it’s only plugged into the MOBO or the psu, but if it’s plugged into both it doesn’t turn on. at first I thought maybe the socket on the psu I was plugging the cable into was bad, so I plugged it into the one my GPU was using, still the PC didn’t boot. I then took my cooler off and inspected my cpu and MOBO, everything seemed fine, nothing looked burnt, but just one pin was slightly bent and it still managed to fit perfectly into the socket.
At this point I’m pretty sure it’s either the motherboard, the cpu, or the cpu power cable. But I’m not sure and don’t know how to test them to single it out. Help would be much appreciated, thank you!
EVGA GTX 1080 FTW
2x8gb 3200 c16 g.skill trident Z
Ryzen 7 1700x
B450 tomahawk max
CX750M (semi modular)
EVGA GTX 1080 FTW
Ryzen 7 1700x
B450 tomahawk max
