PC doesn't power up
Roman Yegorov
11
Hi Everyone! My PC that I built around 5 years ago stopped powering up a few days ago. I've done some tests and determined that PSU is working fine. Also, there are "reset" and "power" buttons that are on the motherboard which lit up once i connect the power cable to the power supply. However, the PC doesn't power up. I suspect it's the motherboard. Anybody has any other ideas? Thanks!
Asus PT6 LGA 1366 I i7-920 I Gskill 1600 6 Mb I Radeon HD4870 I Silverstone ST70F PSU
There is nothing going except for those "Power" and 'Reset" buttons on the motherboard. They get lit up if the power cord is plugged in. Other than that, nothing heppens when i try to power it up. I tested the power supply in another system and it works fine. Not really sure what to do next😱) Thanks for your reply!
Just tried all of what you suggested! Still nothing!
