OK, so VERY broad title, but I must admit I'm very much at a loss as to what's causing this.
So, to begin; about a week & a half ago, I noticed that the sound on my PC was making a slight 'popping' or 'crackling' noise, about every 10 seconds, or when a large dose of sound came about (i.e. Firing the 'Fatman' in Fallout 4). My soundcard, which is an Asus ROG Xonar Phoebus 7.1 (longest name ever) was recently patched to a higher version of the firmware (10.0.1.40 for anyone interested) so I decided to move over to newer Firmware Asus are offering, the SonicStudio 1.1.3 beta, but if anything it made it worse. So I downgraded, and upgraded following the upgrade path, but still no joy. Thinking it was the soundcard itself, I removed the headset from the card and ran it through the in-built sound card on the motherboard, but still the exact same errors. Thinking headset, I swapped my headphones for stand-alone speakers, but I can still notice it, so it's coming from the PC somewhere.
What I also began to notice at the time were some other problems that may have been there previously, but I may not have noticed them, or at least didn't notice until I started playing Mad Max (the game).
The sound stuttering was there, but also some micro-stutter on the screen. Thinking that I'd used too higher settings, I downsized the settings to low to test, and noticed that I was still getting the same issue.
I then tested in a few other games, however I can't say that their results are 100% accurate, as they're notorious for having intermittent framerates anyway (Fallout 4 and Payday 2), so what I decided to was to switch my desktop screen to 144Hz (screen's a G-Sync Monitor) and test with some video instead (speeds here are 71Mbps down and 19.5Mbps up so, pretty good for viewing HD video) and I was seeing the same thing. What I could also see was what is best described as 'input lag' from my mouse. Try the mouse on another PC, no issues, back on mine, lag or at least what is being displayed as lag.
Convinced that something on my PC was now playing up (I really hope it's just a corrupt .dll file I can repair) I decided to go through all the recent changes on my PC.
Firstly, started using Corsair Link on my Corsair H100i. I installed this last year and have had no end of issues with it (I still blame it for killing another Intel i7 6700K I had) namely with the pump making an insane whirring noise on start up and a stranger issue (admittedly, very rare - this happened about 3, maybe 4 times in total since September last year) where the LED will go from White to Red (without the Corsair Link, I'm told this is an error, like the pump or fans stopping) for seemingly no reason. So I finally dug out the Link cable and installed it. The pump still makes the noise but to lesser degrees and it's over much quicker (I'm also told, this is due to the upgraded Firmware). NB: heat; I have a rule originally via CoreTemp and now via Corsair Link to shut down my PC at 65 degrees Celsius and to be honest, the highest it's been this year was 64 degrees.
Secondly, I spent about half a day downloading various mods for Fallout 4, some of them graphical mods, namely the Texture optimisation mod (highly doubt this is at fault), Fallout ENB (a possible contender) and Fallout 4 ReShade (another contender) but I believe if anything, these would only impact the stuttering I'm seeing and not the sound issue.
Lastly, I decided to install the Intel Management Engine about a week ago (after I noticed the sound issue) but again I'm skeptical as to this having any impact as a) it's Intel. I tend to trust what what the publish and b) I've un-installed and re-installed a few times with no notable improvement.
What I'm looking for is not essentially a fix (although if anyone knows whats causing this, I certainly wouldn't turn away your council) but what information I need to trawl through in my PC to identify the root cause.
I have monitored resource monitor just in case my CPU/Memory is flaring up, but aside from some intermittent activity on Core0 (seems to be the only one that ever has full utilisation, but I assume that's from some program that hasn't been optimised for multi-core threading) it's solid as a rock - memory too, but I can certainly do some more recording here and post the results over. NB: I've also used the Intel Processor Diagnostic Tool 64Bit which has passed on each run.
I've also been going through the event logs on my PC, but to be honest I'm not really sure what I need to be looking at - I can see about 4 errors and a s*** ton of warnings which I can certainly break down if anyone's happy to look at them (I'll be reviewing them myself today, but I need coffee first - as I said, a LOT of warnings to go through).
Furmark has also been suggested to see if a problem arises from testing, so I'll be looking to download that later on too.
So, tl;dr - my PC's stuttering, I've done some basic checks, but if anyone's got any other idea's, please let me know.
Thanks all.
Thanks all.
