My PC randomly black screens and reboots with a Video TDR Error that is being caused by Atikmpag.sys. This happens only when the PC is under load (so far only with World of Warships while in port and Civ 6 while alt tabbed). Temps seem fine as I have not seen any issues and Furmark ran fine for both GPU and CPU without getting above 60C for CPU or 90C for GPU (junction temp). I have updated my drivers which did not fix the issue and only seemed to make it more consistent from the last set of drivers where it only happened once on boot up. However, it is still relatively inconsistent with it only occurring four times today.
I do not run any overclocks other than RAM at 3000MHz. However, this error was happening both before and after this was applied. I have also run the Windows Memory Diagnostic tool which found no issue with the RAM.
System Configuration:
CPU: AMD Ryzen R5 2600X
Motherboard: ASUS ROG Strix B450-F Gaming
Memory: 16GB (2 x 8GB) DDR4 3000 MHz Corsair Vengeance LPX
GPU: Sapphire RX 5700 XT Pulse
PSU: Corsair RM650x
VBIOS: 113-1E4112U-045
Driver: Adrenalin 2019 Edition 19.10.1
OS: Windows 10 64 bit up to date
PSU: Corsair RM650x
