So I recently got a new GPU. RX570 - Asus Strix 4GB - Now, the problem I am having also happened once before a few months ago on my old GPU as well. It fixed itself though and now it's back. What's happening is that when I launch a game, the computer just Freezes and the screen goes black and then the computer restarts itself. Please note that since yesterday I have tried 4 different GPUs in the system, all having the same issue. Some games work somtimes and other don't. I have ran a stress test on the GPU too using Furmark and setting the timer to 15 minutes and those tests go just fine without any problems.
The complete system specs are:
Dell T3500
Intel Xeon X5690 @ 3.4Ghz (using this CPU since more then two years now and this has not been changed when the issue started happening)
DDR3 - 1333Mhz RAM. 4GBx2, 2GBx4 - Total RAM = 16GB
an SSD and 2 HDDs.
Asus Strix 570 4GB (earlier card giving the same issue a few months ago was RX460. Also tested RX560 and the same issue persists.)
Dell 525W PSU 80+Silver
2 front intake fans 140MM, 2 back outflow fans 80MM.
All of this running on Windows 10 1809 October 2019 update. Should add that it's been 2 years since a fresh Windows install and I have updated Windows several times with each feature update release.
What am I looking for here? What seems to be the problem? and yes, I have removed old GPU drivers using DDU and installed them fresh.
Dell T3500
an SSD and 2 HDDs.
