PC freezing every couple of minutes.
paulgardiner1
Hi,
Everything on my PC seems to freeze once in a while. Usually this happens if I open an any application but not on every occasion. My screens freeze then around 30 seconds later everything works again and the applications open fine. Even right clicking to correct a spelling mistake when writing this froze the PC.
Earlier today the problem was much worse and nothing was working at all, then I checked Event Viewer which said my secondary 2TB harddrive was about to brea. Removing that alleviated the problem hugely but freezing still occurs as described above.
These are my Specs: http://imgur.com/SEsMOm3 - (Only harddrives in at the moment are the two SSD's).
Fixes I've attempted: Clearing CMOS, Reinstalling windows, removing and reinserting RAM.
These are the only errors I am getting in event viewer:
- App Container profile failed with error 0x800700B7 because it was unable to register the AppContainer SID.
- The CldFlt service failed to start due to the following error:
The request is not supported.
- A TCG Command has returned an error.
Desc: AuthenticateSession
Param1: 0x1
Param2: 0x60000001C
Param3: 0x900000006
Param4: 0x0
Status: 0x1
- The rules engine reported a failed VL activation attempt.
Reason:0x8007232B
AppId = 0ff1ce15-a989-479d-af46-f275c6370663, SkuId = b322da9c-a2e2-4058-9e4e-f59a6970bd69
Trigger=UserLogon(1)
Thanks for any suggestions.
Thanks for the suggestion but I don't know if it will help as stated in the tutorial. I went into resource manager and every processor core seems to be working both when idle and running a game.
