PC Freezing, no overheating
reinah
18
PC is freezing. It happens more frequently when playing games, but can sometimes happen when not. When it occurs in a game, everything freezes and there is no sound, which leads me to believe that it's not a GPU issue but I might be mistaken? Speedfan says everything is fine, not overheating. Did the typical re-seating of everything and reinstallation/update of drivers.
I had this issue: http://www.tomshardware.com/answers/id-2732931/ethernet-valid-configuration.html which I "resolved" by reinstalling Windows, but the PC keeps freezing. I think it might be an SSD problem, but I have run disk checks and the Samsung Magician software says everything is healthy.
I set the RAM to run at 1866 (that's what the processor caps at) so it wouldn't be overclocking, but that didn't solve it. I also let Memtest86 run for 19 hours, but everything passed.
Specs:
ASUS Crosshair V Formula-Z AM3+ AMD 990FX + SB950 8 x SATA 6Gb/s USB 3.0 ATX AMD Gaming Motherboard with 3-Way
AMD FX-9590 Vishera 4.7GHz Socket AM3+ 220W 8-Core Desktop Processor - Black Edition FD9590FHHKWOX with Liquid Cooling Kit
G.SKILL Sniper Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) Desktop Memory Model F3-2400C11D-16GSR
ZOTAC ZT-90503-10P GeForce GTX 980 Ti AMP! 6GB 384-Bit GDDR5 PCI Express 3.0 SLI Support Video Card
SAMSUNG 850 EVO MZ-75E250B/AM 2.5" 250GB SATA III 3-D Vertical Internal Solid State Drive (SSD)
EVGA SuperNOVA 1000 G2 80+ GOLD, 1000w Fully Modular NVIDIA SLI and Crossfire Ready 120-G2-1000-XR
Any help would be appreciated. Thanks!
My BIOS is up to date. I don't know how to tell what rev the MB is? I also forgot to mention that I have a 1000w PSU
Yep. And no peripherals outside of GPU.
So far it's looking like it might be a faulty mobo. Still worth trying would be to remove one of your RAM modules (i.e. run it in single channel mode). If it still crashes, swap with the one you took out and put it in a different slot. Also swapping your GPU with someone else's (or an old one you might have kicking around) is always worth trying too (Intel CPU's have integrated graphics, which makes eliminating the GPU as the culprit simpler).
Moved the RAM around but don't have another GPU. Not sure if after 18 hours of memtest taking 1 stick out would do anything, but i'll try it later.
I have used AMD Overdrive, Speedfan, and CPUID HWMonitor and they all say the same thing: My CPU is around 45c when taxed.
The CPU cooler is one of the Seidon 120's (I think the M)
Ok! Grabbed Prime95. It's running about here before freezing, but it is causing it to freeze faster and regularly
usually about 5-10 minutes in. Not sure what that means.
I haven't done any OC, I just put it in and ran it with the default settings.
*edit* I know the Black Edition is usually factory OC, right? I don't know how to lower the voltage properly.
If I don't have a replacement GPU, do you think that RMAing the mobo would be the best option? Is there a diagnosis besides "everything else seems to be okay?" Trying to figure out the best route to take here. Thanks. :)
I also ran more tests on the RAM: Individual sticks with Prime95 and both froze, I'm pretty confident it's not the RAM.
