Question Pc Freezing now won’t display anything B550 motherboard
Blairzxy
18
B550 A motherboard won’t boot up
So the other night I was playing my pc and all of a sudden it just froze no blue screen just completely froze on the screen I was on which has never happened to me before and I have been running this setup for about a month and i half no problems at all. I then had to turn it off at the back with the switch as my power button would not turn it off I put it back on and it happened again pretty quickly I thought maybe it was my ssd so installed windows on a new ssd I was going to install anyway it worked for a little bit then happened again i then started trouble shooting some stuff like my ram and had it down to one stick of ram it ran destiny for about an hour no problem so I thought ok must be one of my ram sticks causing it so I put another ram stick in and it froze again then I tried to take it back out and it just would not display anything at all none of the small led lights would display anything on my Mb next to the ram so I had no idea what was up with it. I seen about updating the bois so I done that then booted up with one stick of ram in it then after I went to put more in it won’t display again.
Tried it without my gpu in doesn’t display anything
Tired another old gpu got nothing as well
Cleared the CMOS and the battery.
Specs
Components
Amd Ryzen 7 5700x
Rog B550 A motherboard
32Gb Corsair vengeance pro 3600mhz
Rtx 2080 super
Corsair 1000w psu
1tb Samsung SSD
1tb M.2 Nvme
