PC Gaming Build India
DarkCobalt
19
Hey friends please help me build a new gaming PC. I am from India and my budget is 50,000 rupees.
I would like to play games till 2018 in mid settings with 1366x768 resolution.
Thanks in advance
hey, as you're from india, i can suggest a good site https://www.theitdepot.com
First I shall talk only of the rig.(excluding peripheral devices)
At the site, they sell combos,so get
1.Intel Core i5 6th Gen 6500 3.2 GHz + MSI B150M PRO-VDH 64GB DDR4 + G.skill 8GB (1 x 8GB) 2400MHz
2.Asus GTX950 2GB DDR5 Graphic Card (GTX950-OC-2GD5)
3.Deepcool Tesseract BF Mid Tower Computer Case - Black
4.Seagate Barracuda 1TB 7200RPM SATA Internal Desktop Hard Drive (ST1000DM003)
5.Deepcool 500W Power Supply 80Plus Bronze Certified (DA500)
This rig would level off at...
This rig would level off at 50k, you would have to purchase other peripheral devices like keyboard, mouse, speakers and monitor
But if u want everything within 50k ..well here's what you've gotta get>>
1.AMD FX-Series FX 6300 6-Core Processor
2.MSI 970A-G43 32GB DDR3 AMD Motherboard
3.Kingston HyperX Fury 8GB 1866MHz DDR3 RAM - Red
4.Asus Radeon R7 360 2GB DDR5 ATI PCI E Graphics Card (R7360-OC-2GD5)
5.Toshiba 1TB 7200RPM SATA Internal Desktop Hard Drive (DT01ACA100)
6.Deepcool Tesseract BF Mid Tower Computer Case - Black
7.Corsair VS Series VS450 450W High Performance Power Supply (CP-9020049-WW)
with this you would have around 13k or 14k remaining with which you could purchase a decent monitor,keyboard and mouse!
On a side note the msi 970A-G43 has crossfire support so that in future it may come to use!
Wish u Luck!
Thank you very much for helping but there's one more thing I forgot to mention that I already have Keyboard, Mouse, and Sound system. I just need a new PC and Monitor.
if u r seriously limiting ur budget @ 50k then i guess u will have to go for the second option as u can get a very good monitor for 13-14k.
but if u can pay a tad bit more...the first one seems fitting 🙂
I will go for the second option as it suits my budget more and one question what is better FX 6300 or i3 6100
Yep take an i3 6100 but then u have to get a ddr4 supporting motherboard such as Gigabyte GA-H110M-S2 DDR4 Intel 6th Generation Motherboard LGA 1151/ Intel H110 and a DDR4 ram it would cost around the same but AMD is more optimized for gaming. So make a wise choice,depending on what u r going to use it for.
Hey jerry I looked up on Gigabyte's site the board supports only DDR3 RAM. Maybe I should go for another board. What will you recommend?
Thanks for the help.
And now one final question will Nvidia and AMD release their new cards before July. Should I wait for them for or go with the current gen?
Haha it depends on your patience mate, if you wanna lay your hands on the pc ryt now, go ahead .. Else wait..
If I were you I'd buy everything except the GPU, and wait 🙂..coz the motherboard and cpu are latest ones and no compatibility issues would be faced with the new GPU.
Yeah this sounds the best idea. Thank You
