So an unusual problem occurs when I plug my bluetooth dongle into the PCIe USB card. My system fails to boot. It hangs after POST and fails to boot into Windows.
Now this doesn't happen when the dongle is connected to the front panel USB hub nor the built in USB ports on the Mobo. I've isolated it to the PCIe card as I've also tried a friends Belkin bluetooth dongle and the same occurs.
It also happens with a USB M2 card adapter, but not with USB flash drives. The reason I wanted it connected to the card is to put the dongle on one of the internal ports to give my system bluetooth functions.
The card is powered via the SATA power cable.
Any suggestions? Any additional info required?
System:
Intel i7 6700k
Asus Z170 Pro Gaming
CSL - 7 Port USB 3.0 PCIe Controller | 5x External (Ports) / 2 x Internal | 15 pin SATA Power Connection
Tendak USB 3.0 4-Ports 3.5 inch Metal Front Panel USB Hub with 15 Pin SATA Power Connector
Asus USB-BT400 3Mbps USB Bluetooth v4.0 Mini Dongle
nVIDIA GeForce GTX 970
Samsung 2.5-Inch 250 GB 850 EVO SSD
Win10 Pro
System:
Intel i7 6700k
Win10 Pro
