Hi all! I'm hoping for some help and advice. I have a custom build gaming PC, built way back in the ancient times of 2012. Here are it's specs:
OS: Windows 10 Pro 64-bit
MOBO: Gigabyte X79-UD5, Intel X79 chipset quad channel DDR3 ATX
CPU: Intel Core i7 3820 @ 3.60GHz quad-core LGA2011
RAM: Corsair Vengeance 16.0 GB (4GB x4) @666MHz
GPU: EVGA GeForce GTX 960
PSU: Thermaltake Toughpower Grand 1050W
Cooling: XSPC water cooling kit (not sure what the kit name was). It has a 240mm radiator w/dual fans, open loop soft tubing connected to the CPU only.
HDD 1: Samsung EVO 500 GB SSD
HDD 2: Seagate Barracuda 7200 1TB (x2 connected RAID 0)
Case: Thermaltake Level 10 GT Full Tower (snow white edition)
I've done my best to take care of it and it still runs. Spent a bunch back then to get something I knew would last. Since then, the only components I've replaced were the main hard drive which started to crap out (it was an Intel 250 GB SSD), and the graphics card which suffered a red screen of death (original was an NVIDIA GeForce GTX 670 ). Also updated the OS from Win 7 to Win 10. And while it still runs and can handle most modern-ish games with High settings, it's getting old. I'm starting to window shop for parts, but my greatest confusion lies with compatibility.
My first concern is the case itself. I'd love to keep my case and I'm hoping it'll work with new parts. It's big and very easy to open and take apart. My current 10.5" by 12" motherboard fits with ROOM to spare. It also has a ton of fans and some neat RGB lighting effects. Link to it: https://nordic.thermaltake.com/products-model.aspx?id=C_00001788
I'm sure folks here might tell me to chuck it and start over, but other than my own personal nostalgia and attachment, I'd like to save the money on that upgrade if I can.
As far as components go, my primary concerns are the motherboard and CPU. I'd love to step up my processor to an Intel Core i9 and a good gaming motherboard that's compatible with that 10th gen chip. Any suggestions? I have my eye on the MSI MPG Z490 Gaming Carbon WIFI MOBO.
My secondary wishlist of upgrades would be the RAM and graphics card. I'm looking for parts better than what I have but don't have to be most expensive/top of the line. Help with how to determine what will work with what would be really appreciated.
Lastly, what do you all think I can/should continue to use from the setup I have? Should I keep using the 16 GB of RAM I currently have, and will it work with a new MOBO? My PSU is still working fine, but is the wattage enough? Is it old enough that it's better off replacing? And who here is using an AIO water cooling kit they really like? I'm sure I'll have to replace that as well.
Thank you for reading, and I appreciate any suggestions!
