Question PC has become extremely loud and turns itself off when starting to stream in OBS ?
MickeymouseisZelda
Commendable
Dec 1, 2022
11
Hello everyone!
My friend recently gave me his old gaming desktop, he wasn't sure if it worked or not. I booted it up today, launched Marvel Rivals and I was able to play completely fine. Once I selected Start Streaming from OBS, the game loads for about 2 seconds, the computer crashes and the graphic card starts yelling. I am not certain but it appears the temperatures are okay, the highest being 72c on one of the cores.
I went to the event viewer and got this after the crash:
Event ID 41: "The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed or lost power unexpectedly."​
If there is any additional info needed, please let me know. Thanks!
Here is the computer shutting off: View: https://imgur.com/a/Uhqi8ms
Specs:
-Windows 10
-Intel Core i7-9800k CPU @ 3.60z 3601 MHz, 8 Core
-Gefore RTX 2070Super
-16GB of Ram
Specs:
-Windows 10
-16GB of Ram
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
You're sure you didn't mean to mention an i7-9700K?
CPU:- Processor Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz, 3601 Mhz, 8 Core(s), 8 Logical Processor(s)
CPU cooler: Not sure if I have one, please let me know how I can get this info
Motherboard: BaseBoard Product Z390 Phantom Gaming 4-CB
Ram: 16GB (Please let me know how to get the exact name)
SSD/HDD: Model ADATA SX6000LNP
GPU: Geforce RTX 2070Super
PSU: Working on getting this (will update)
Chassis: BaseBoard Manufacturer ASRock
OS: Windows 10
Monitor: Asus
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time: It says it was built in 2023 but I dont believe it was used that often.
Below is the system info, maybe this will have info needed:
View: https://i.imgur.com/NLB8dOg.png
Let me know if there is any additional info needed.
Also check your reliability monitor by simply searching for it after pressing the windows key. Look for hardware errors and such, as they point you somewhat into a direction. In the windows event viewer you will most likely find more information though. Same principle as to how to open it.
It also seems like this might be an issue with Marvel Rivals, I loaded up two other games and it seem to run fine.
So maybe the computer is over-heating with Marvel Rivals?
Edit: So it just appears to be Marvel Rivals that is the issue. I can play for half a game, then it either crashes the game or shuts the computer off.
That's a GPU VRAM crash probably due to unstable current flow as mentioned
So I ended up changing the Shader Cache Size to 5GB inside of the Nvidia settings and there has been no crashes! The performance is significantly worse :/ but I guess its worth it not crashing.
Does anyone know if I should change these settings anymore? My graphics card is 8.0GB of dedicated memory, so I figured I should do 5GB.
Nvidia settings:
View: https://imgur.com/a/lFe4xxY
