Hello, new to the forum. As the title says, my pc wont post and only shows a black screen with no display. Im building a pc from scratch after my old motherboard had bent pcie pins. I have a speaker plugged into the motherboard but it doesn't beep.
What ive tried:
Bought an Asus mini itx motherboard(my old pc was a msi nightblade x2)
Bought another Asus motherboard, This time a micro atx. Both motherboards have 1151 6th gen sockets so they are compatible with my i7 6700k.
Used my girlfriends old Cit 600w psu and my old 500w psu(yes both are cheap and a little bit old but they both work fine)
Tested my rig with 2 different monitors along with different connections, dvi and display port
Tried my ram sticks in different slots and tried them 1 at a time.
Made sure the 24pin and the 4pin psu power connections are in.
Re-seated the gpu and made sure the connection is fine.
What ive not tried:
My cpu fan is plugged in but its not covering the cpu and its not screwed down(ordered a backplate today)
Tested different RAM into the dimm slots. My motherboard supports only ddr4 ram which i have but not sure if there is speed compatibility issues. Again i bought a new ddr4 ram stick today.
Tested a new good quality PSU.
My pc's main specs: i7 6700k cpu, 1070 gpu, 600w cit psu, 2x 8gb ddr4 ram, H110M-K mAtx motherboard.
Any help is appreciated, thanks!
What ive tried:
What ive not tried:
