PC has power but not turning on
Scottishrequiem
79
I recently took out my GPU to inspect for damage/dust as the GPU was running quite hot.. I also switched my H100i v2 to pull air out instead of in.
Any troubleshooting paths for me to take??
I went to turn on my PC, it's receiving power to the motherboard as lights are on but the power button is doing nothing, system is not turning on..
I'm going to try removing all cables and reinserting them incase something has moved or dislodged but this is really weird..
It's a new system only a few months old.
Take out the CMOS battery for a few seconds and reinsert. See if the system POSTs now. If it doesn't, remove all but one stick of RAM, remove the graphics card and connect your monitor to integrated graphics to see if computer POSTs.
What are your specs? Make and model of PSU? If the above doesn't work, run your system on another power supply.
I took out CMOS and reinserted it, I'm assuming with power disconnected
i7 6800k
h110i v2
Asus x99a-II
4x8gb Corsair Vengance LED
GTX 1070 Asus Strix OC
EVGA G2 SuperNOVA 650W
