G
Guest
Guest
Do these voltage readings indicate that the PSU is working properly, or does it seem like there could be an issue? I'm mostly concerned with the 12V reading that i'm getting
3.3V I got 3.325
5V I got 5.003
12V I got 11.968 sometimes saw it drop for about a millisecond to 11.8xx
HWmonitor however shows completely different readings! for the 12V it says that its only 8.2 and if that was try I doubt the system would even boot.
Here are the specs for my system
Corsair TX850 PSU
i5 2400 @ 3.1ghz 3.4ghz turbo
Nvidia gtx 680
8gb Corsair vengeance ram
MSI z77a gd65 motherboard
Also do you guys think that the TX850 is a good enough power supply to be able to sufficiently run what I currently have, or do I need to upgrade that to something better? I bought a gtx560ti with this PSU and everything else so I was sure at the time that the Corsair 850W is more than enough. In the future I'm planning to upgrade my cpu to an i7 and I'm assuming that i'll have to upgrade my psu regardless, but I still want to know what you guys think.
3.3V I got 3.325
5V I got 5.003
Corsair TX850 PSU
Nvidia gtx 680
