Hello guys this is my 2nd time posting as for some reason i have tried everything in my head and am still not sure what it is so my specs right now are , the system seems to be just cutting out this has never happened before the only way the system will stay running when using max power is with one PSU for the GPU and One for everything else so i dunno if the PSU's am buying are faulty and if i should change brand or not please help
Processor: AMD FX -8350 8 Core clocked @ 4.0Ghz
GPU: EVGA GTX 770 SC 2GBGDDR5
RAM: HyperX Furry Ram clocked @ 1833Mhz
Motherboard : Gigabyte GA-970A-UD3P
CPU Cooler: Cooler Master Evo 212
SSD: Crucial 256GB SSD For OS
HDD: 3TB WD Green 7200RPM For Games And Software
PC CASE: Zalman Z11 Blue
PSU: CIT 750 Watt 12v Dual Bronze
Temps Idle
CPU : 25c
GPU 36c
Temps Max
CPU:52c
GPU:80c
Temps Idle
CPU : 25c
GPU 36c
Temps Max
CPU:52c
GPU:80c
