Question PC help with CS GO
Apr 5, 2021
6
I bought a gaming pc from i buypower and my experience in cs go has been terrible heres my specs my old pc ran it much better with way worse specs i7 gtx 970 500 watt psu 16 gigs ram
New PC Processor Intel Core i9-9900KF
Cooling Thermaltake Water RGB Liquid cooling
64gb Gskill Ripjaws V
Geforce RTX 2080 SUPER
MSI MAG Z390 Tomahawk
1200 watt psu 80 plus gold
500 gb WD SSD Itb Hard drive Windows 10 I game on a 240 Hz gigabyte Aorus KD25F fps is great inet connection is great the game is choppy and looks like tearing or bottle necking but im not sure please help
Lutfij
You could try downloading the latest drivers for your Nvidia GPU from Nvidia's support site. Then use DDU to uninstall your existing GPU drivers. Reboot, then reinstall your GPU drivers in an elevated command, i.e, Right click installer>Run as Administrator.
See if that helps. You could also try and uninstall and reinstall CS:GO.
Model for your PSU? BIOS version for your motherboard? Version for your OS?
Apr 5, 2021
6
I just recently purchased a custom gaming pc and to be honest I spent a lot of money And pretty disappointed at how bad my performance is in games not quite sure if I’m doing something wrong I bought all top of the line parts Item Quantity Subtotal Price Holiday Gaming RTX 2080 SUPER 1 $3,284.00 Case Thermaltake Level 20 MT ARGB Tempered Glass Gaming Case iBUYPOWER Elite Build Package Elite Build Package - Silver (Pro Wiring, Sleeved Cable - Choose a Color Below) - Red Cable Case Fans 3x [RGB] Corsair ML120 PRO Premium Magnetic Levitation 120mm Fan Case Lighting iBUYPOWER RGB Lighting - [FREE] 1 RGB Lighting Strip Processor Intel® Core™ i9-9900KF Processor (8x 3.60GHz/16MB L3 Cache) Processor Cooling Thermaltake Water 3.0 360 ARGB Sync Edition RGB Liquid Cooling System Memory 64 GB [16 GB x4] DDR4-3200 Memory Module - GSKILL Ripjaws V Video Card NVIDIA GeForce RTX 2080 SUPER - 8GB GDDR6 - ASUS DUAL EVO OC (VR-Ready) Motherboard MSI MAG Z390 TOMAHAWK -- RGB, ARGB Header (1), Gb LAN, USB 3.1 (1 Type-C, 3 Rear, 4 Front) Power Supply 1200 Watt - Standard 80 PLUS Gold, Full Modular Advance Cabling Options Standard Default Cables Primary Hard Drive 500 GB WD Blue SSD -- Read: 545MB/s, Write: 525MB/s - Single Drive Data Hard Drive 1 TB Hard Drive -- 32MB Cache, 7200RPM, 6.0Gb/s - Single Drive Sound Card Creative Sound Blaster Zx [PCIE] -- 5.1 Channels, 96kHz/24-bit, 192kHz/24-bit (Stereo Direct), 116 dB SNR Network Card Onboard LAN Network (Gb or 10/100) Operating System Windows 10 Home - (64-bit) Monitor 24.5" [1920 x 1080] GIGABYTE AORUS KD25F Gaming Monitor - 240Hz 1ms + AMD FreeSync - Single Monitor Keyboard iBUYPOWER Standard Gaming Keyboard - Free Upgrade to iBUYPOWER Standard RGB Gaming Keyboard Mouse iBUYPOWER Gaming Optical Mouse - Multi-Color LED Lighting Headset HyperX Cloud Flight Wireless Gaming Headset w/ Detachable 3.5mm headphone cable iBUYPOWER SafeGuard Packaging iBUYPOWER Specialized Advanced Packaging System - Protect your investment during transportation! Advanced Build Options - Thermal Paste Thermal Grizzly Kryonaut Thermal Grease Paste - Top of the range thermal paste with excellent please help
Apr 5, 2021
6
Thank you I’ve done all that but haven’t done it in administrator yet so I’ll try that for my specs I should be running cs go great it stutters and freezes during spraying and gun fights fps is solid and internet connection is good nvidia settings are optimized just about everything you can think of I’ve done I’ve tested multiple monitors multiple gpus the only thing I haven’t checked is psu and liquid cooler but temps are great well gaming so definitely not an issue I wonder if it’s a bios issue I wish I new more so I could diagnose the problem myself
dorsai
Tearing is usually a G-sync issue...make sure you have it turned on in the nVidia control panel...you might also want to try a frame cap at 240fps.
