Question PC Idle problems
Jul 8, 2019
48
When I leave my PC idle when I sleep, after I wake up and then use it, it'll BSOD, sometimes only a glimpse and then turn black. With lights and fans working, then it won't boot unless I reseat the RAM sticks.
ASUS b450m
x2 Corsair Vengeance 8gb DDR4
RX 570 nitro sapphire 8gb
WD Green 240gb SSD
Corsair VS 450W
48
Vic 40
Polypheme
Ambassador
You have different options when right clicking the start menu for what to do with the pc, i.e. powering down or set it to sleep. You seem to let it run,but idle. What happens when testing sleepmode?
Jul 8, 2019
48
Heya, im back. The same thing happened and I did a quick test with the RAM sticks. So, i've been using slot 2 and 4. It won't boot so I tried with one, worked perfectly. Put on the other and it won't work again, now with that other stick by itself, no boot. Tried in both slots. The first RAM stick that worked, works alone with both slot though. Could this be a 100% faulty RAM stick?
Edit: Note that I have DOCP off, if it's any relevant.
Vic 40
Polypheme
Ambassador
Memtest isn't always right. Still think that if one stick gives problems an rma would be wise. Or the motherboard has a problem with it, but then would (if on the latest bios) it maybe be good to rma motherboard.
