Question PC is Eerily Quiet, Please Help!
Hypoltan
234
Bit of a confusing story, so please stay with me. Also, I am a novice in PC building, so forgive me for lack of simple knowledge.
I was recently fiddling around with my PC, trying to install an HDD. After successfully completing that, I turned my PC on, yet none of the case fans were running. Fixing the fan headers to their correct places, I once again turned on my PC, and everything seemed fine. However, I realized that the PC itself seemed really quiet, like much quieter than it was before.
My notable specs are:
Gigabyte rtx 2070
Noctua D15s
Case fans are the Dynamic X2 GP-12 that come with the Meshify C and 2 more that are around the same sound level
Out of all my fans, I think it is from the GPU fans, which is the loudest component of the build. Strangely enough, I've looked at all my fans (GPU, CPU, case fans) and they are all spinning. Even more strange is that when running my games, the frames and component temperatures seem normal (from what I recall), the gpu in the high 50's to low 60's. I've checked MSI afterburner, the fan speed is as usual (at 25), even when turning it up to 100 it is only slightly louder. I am not sure if I unplugged something, though everything is running more or less normally, just a whole lot quieter.
I understand this is a very weird situation, but please any help would be really appreciated.
