PC is on 'working', unexpectedly the monitor goes blank and shows no signal.
SushilP
PC turns on properly, you can work on it, play game, pump the cpu to 100% nothing goes wrong, but after some time, the monitor unexpectedly turns black and show no signal, not because you are using the cpu to its fullest, it even happens the cpu is idle and nothing's going on.
There's no way to get the signal, the only way is to restart.
PC doesn't turn off, the monitor just shows "No signal".
