Question PC is running but Keyboard/Mouse/Monitor are not working after upgrading CPU and GPU ?
dawid.mohammedi
12
Hello
After swapping GPU and CPU, keyboard/mouse/monitor are not responding ?
Current setup is
GPU - RTX 3060
CPU - AMD Ryzen 9 5900X
Motherboard has an AM4 socket
Those are the 2 bits which were upgraded so I'm not sure why all of a sudden everything would stop working the way it was before.
dawid.mohammedi
12
My bad and thank you for moving the thread
Mobo:B450m motherboard
CPU:AMD Ryzen 9 5900X
GPU:RTX 3060
PSU: Aerocool 750 Watts 80 Bronze
RAM:16gb(2x8) Corsair 2400 mhz ram
dawid.mohammedi
12
Odds are your motherboard needs an update in order to boot that CPU
That is really odd I was hoping that it will work all fine just after swapping the CPU and GPU but when you mean update you mean the actual software on the motherboard? At the moment nothing is accessible when I turn on the PC the lights are coming on for the PC tower but the keyboard mouse or monitor is not coming up with anything as if there is no signal going in there
What motherboard? There are dozens of b450 motherboards!
dawid.mohammedi
12
Correct. Flash the proper BIOS making sure to read carefully as you my need to update incrementally to the latest stable version.
On it right now and I just need thermal paste and I don't see now a reason why it may stop working, just wanted to check if small amounts of thermal paste around the pins may cause any problems?
Satan-IR
Ambassador
In CPU-ThermalPaste1 image it seems like there's some paste on the inner square pins too? How did that happen? Is the socket clean? No paste in the little holes? Because if there is any and if the paste compound contains any conductive material it might still not work.
Even if it's such amount like in the pictures below?I do apologize if that sounds dumb
There are no "dumb" questions. We all started learning about this stuff at some time.
Latest posts
