Starting around a month ago I started having an issue with my computer where the wifi adapter I was using for my computer would be getting about 3% the MBPS it would usually get. From there I assumed it was failing so I got a new one. I replaced it with a Thumb Drive adapter and every thing went smoothly for a little while until that one too would begin to slow immensely. When the adapter began to slow I could always fix it by uninstalling the drivers for the adapter completely and then reinstalling them again. This will again fix the problem for a short time (30-90 minutes.), but soon after than my USB drives will all begin to fail. The thumb drive adapter will disconnect and my usb to aux connecter will stop working, and eventually the mouse and keyboard as well.
Troubleshooting: I have checked the temperature of my PC and the components but that doesn't seem to be an issue at all, I have checked the power supply but all sources point to that being solid. It's obviously a larger problem then the wifi adapters themselves and I'm just at a complete loss for what to do OR what's causing it. I've already tried wiping my computer my computer but that did diddly squat, so I'm leaning towards this being a hardware issue rather than a software one.
Any tech gods out there got a clue what's going on?
Specs:
CPU: AMD-fx 6300
GPU: AMD Radeon R7 360
Motherboard: ASUS M5A97
OS: Windows 10
Specs:
CPU: AMD-fx 6300
OS: Windows 10
