I'm completely new to building a PC and followed the directions as best as I could, but I didn't understand everything. I'm worried something is either defective or it could just be wiring.
I was linked to a sticky on this site on first time builders' main issues or something like that. None of the items listed were the problem. I'm really at a loss here. The PSU is a Corsair TX650.
I have:
The CPU cord plugged in (only half of it needed to be used)
I have the big 24 pin connector put in the only slot available
The "AC'97" cable plugged into a pin connector with "AAFP" next to it
I have the LED's plugged in
The power button and reset button (I suppose I should mention, I'm using a Thermaltake Dokker case)
The SATA cables are plugged in
One of the PCI-E cables is plugged into the 7850
And that little thing that says "SPEAKER" is plugged in.
That's it.
Nothing works. I flipped the back switch. Grounded the MOBO properly, and have most everything hooked up.
Any ideas?
I have:
That's it.
Any ideas?
