GPU: 3060 Ti
OS: Windows 10
Sometimes when i turn on my second monitor my pc just freezes and then reboots and says:
The description for Event ID 0 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\000000b8
Resetting TDR occurred on GPUID:500
OS: Windows 10
\Device\000000b8
