I have a 7 year old pc, and lately it restarts itself a lot, so i thought it must be the psu or its because its so dirty inside, so i decided to clean the entire pc (i didnt took anything off except for the gpu and cpu heatsink). I cleaned the dusts on the case with soft cloth, and brush the hard areas with toothbrush (and a bit of water). There was a lot of dust in there, so it was very satisfying to clean the whole system.
After im done i fired it out and it sounds a lot quieter so i thought i've fixed the problem. But when i start gaming, the fps is A LOT less than it used to be, and the pc keeps restarting itself every 5 minute. I checked the fans, theyre spinning tho.
What should i do? Am i doing anything wrong? Thx in advance.
The pc has an i5 750, an HD5500, 4gb of ram. The psu was unbranded, but i doubt it was the one causing the lag because it was fine before.
Extra details:
-The cpu heatsink was positioned differently than before because it wouldnt fit in. It fits fine now
- i didnt double check the gpu positioning, but it seems fine
- its not actually restarting itself, it just suddenly went blank (the monitor says no hdmi plugged in) and i cant do anything but restart it.
Extra details:
