Hi,
I have been experiencing a problem ever since buying and installing new Power Supply and Graphics Card from Newegg.ca. While playing video games (doesn't matter if they are new games or older games) my PC will randomly lock up (sound will stutter) and then after about 5-10 seconds, my PC restarts. It can happen within minutes of launching a game or after an hour or two. Sometimes it doesn't happen at all...
I've replaced my Power Supply with a new higher quality one in hopes that because I had cheaped out on the first one, a higher quality one would be better. It didn't solve the problem. I also uninstalled and reinstalled my graphics card to see if that would make a difference (along with the drivers) but that did not work either.
I use all my components on stock settings and I've got CoreTemp logging my temps to make sure I'm not overheating.
Windows 8.1 64-bit
Motherboard (http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128565)
16 GB RAM (http://www.newegg.ca/Product/Product.aspx?Item=N82E16820220619
AMD-FX 4130 (3.80 GHz) Quad Core Processor (http://www.newegg.ca/Product/Product.aspx?Item=N82E16819113291)
AMD RAdeon R9 290 (http://www.newegg.ca/Product/Product.aspx?Item=N82E16814121842)
EVGA SuperNOVA 1000W P2 (http://www.newegg.ca/Product/Product.aspx?Item=N82E16817438013)
After my most recent crash this morning, the following errors were in Event Viewer:
http://i197.photobucket.com/albums/aa58/Krispiterian/PC%20Errors/error3.png
http://i197.photobucket.com/albums/aa58/Krispiterian/PC%20Errors/Error1.png
http://i197.photobucket.com/albums/aa58/Krispiterian/PC%20Errors/Error4.png
http://i197.photobucket.com/albums/aa58/Krispiterian/PC%20Errors/error2.png
Really would appreciate any help I can get on this, I'm starting to run out of options here.
Windows 8.1 64-bit
