[SOLVED] Pc losing connection randomly
Dec 19, 2019
4
So i have been dealing with this problem for a while now. I pc randomly loses its connection. So ill play an online game and ill get disconnected from internet for 10 sec. I changed the router,cable. The carrier changed some settings for me but it didnt fix it.
Opis: Killer E2200 Gigabit Ethernet Controller
‎44-8A-5B-9E-C4-CD
DHCP is enabled: Da
Naslov IPv4: 192.168.1.2
Maska podomrežja IPv4: 255.255.255.0
Privzeti prehod IPv4: 192.168.1.1
Strežnik DHCP IPv4: 192.168.1.1
Strežniki DNS IPv4: 8.8.8.8, 8.8.4.4
Strežnik WINS IPv4:
NetBIOS prek TCP/IP je omogočen: Da
Naslov IPv6 lokalne povezave: fe80::f898:cf75:d57:ac21%10
Privzeti prehod IPv6:
Strežnik DNS IPv6: 2a00:ee2:4b00:300::1
If you have any suggestions please do tell.
So i fixed it. I did some googling. The problem was my network card was not set to work on full duplex. Now that it is on full duplex it works.
Maybe you could try rolling the drivers back a few versions
This really does sound like a Windows configuration issue and probably just a wrong driver got slipped in by Microsoft or somebody
Can you tell where can i get a different driver. I've had this problem for almost half a year now
To eliminate the potential issue with drivers, try a linux live cd and see if you have any disconnect issues when accessing the internet. If you do, then it could be hardware like the nic, cable or even the router. If you don't, definitely a driver issue of some sort.
Reactions: tingety
