Hello everyone,
1 year ago i built my own pc, and i has been running smoothly every since till today.
Because my initial built only had a 250 GB SSD, i wanted to upgrade with 1x HDD of 1TB.
So today i install the HDD when everything is turned off. Connect SATA, Connect PSU.
Then i try to boot my pc again, and suddenly this very loud noise start to appear at start up.
first its mediocre, but as the pc boots up, it gets louder and louder till it reaches like a constant volume. then when it has booted, it often lowers a bit again.
I didn't think this was a good sign. so i put off the power, and removed the HDD again.
Now my built was like it was before..i try to boot my pc. Nothing happens. Everything is plugged in, the on switch is on, psu plugged in net etc.
Does anyone know what is causing the problem and how to fix it?
This is my built for more info:
PSU: Sea Sonic S12II-620 Bronze (620 watt)
Screen: Iiyama ProLite XB2380HS
Case: NZXT Crafted Series Phantom 410
RAM: Kingston HyperX Beast 2x4GB
CPU: Intel Core i5 4670K / 3.4 GHz - 6 MB cache - LGA1150
MOBO: Gigabyte Z87X-D3H - Moederbord - ATX - LGA1150 Socket -
Z87 - USB 3.0 - Gigabit Ethernet - HD Audio
GPU: MSI GTX 770 Gaming 2 GDDR5
SSD: Samsung 840 EVO Basic - Solid state drive - 250 GB
New HDD: WD BLUE 1TB
