Hi,
I wasn't sure where to post this one, so apologies if its in the wrong place.
The status of my pc is that when I switch it on, nothing happens apart from what I can only describe as a kind 'purring' noise coming from the analogue (extenally powered) speakers! No boot-up, no lights etc. Power cord is fine. 8O
Prior to this I had been having BSOD STOP error messages, which had been forcing me to reboot. Thinking I had a problem with one of the two hard drives in my box, I ran the Maxtor diagnostic utility (PowerMax) on them, but no probs found.
I removed the drive I keep my 'docs' on and put it in an external HD enclosure, leaving my 'system' drive in the box. The system boots up fine a few times, and now no BSOD after the startup process as it had done previously. Now I try and plug in (USB) my HD enclosure, get loads of "Hardware / USB Device not working properly" messages from the system tray, and then the pc just dies and won't switch on again! All it makes it this 'purring noise' when the power cord is in.
I think I've brought this on myself, since I realised that I didn't set my 'docs' drive to master before I fit it into the enclosure, but didn't think for a minute that it would completely nuke my sytem.
So, do you think I've fried my Mobo, PSU, or both?
Any help appreciated.
XP Home,
Gigabyte K8NS Pro (Sempron 3000+)
Maxtor 120gb & 78gb
XP Home,
Maxtor 120gb & 78gb
