Question PC/Monitor/Speaker best audio cable settings?
Mar 25, 2019
16
4
15
Hi,
I know I don't have a professional audio system, but I was still wondering if my current cable connection setting is correct to obtain the best results.
I have the Bose Companion II speakers , the Aux In port is connected to the monitor and the bottom one to the Motherboard.
View: https://imgur.com/a/3JH9QGe
The Monitor is connected to the Video card (GTX 1080ti) using an HDMI cable.
In the audio settings on windows, I can select 2 audio source:
  • (Realtek something) which I suppose is the audio from the MOBO (currently selected)
  • the Monitor one.
Which one should I use?
2) Also, both MOBO and Monitor have optical ports...should I use it even if the HDMI connection?
