PC much slower than normal
Teplous
18
I have absolutely 0 clue why my pc has become much slower. I have a pretty decent build, with an R9 270x, 8gb of ram, samsung evo 128gb ssd, 1tb hdd, i5 4670. It was fine earlier in the morning, and I had noticed a slow down when my FPS dropped below 60, where it's usually 300+. Anyone have a clue on whats wrong? Any help would be amazing!
List your build - make and model of every component and the OS you're using.
Use HWInfo (download for free) to measure the voltages from your power supply.
What voltages are you getting for the 12v, 5v and 3.3v rail? - min and max for each?
Is the gpu or cpu overclcoked? What frequencies and voltages?
What temps are the cpu and gpu at?
Is it only one one game? Which, with what settings?
What monitor are you using? Make and Model
What resolution?
@Kippohippo I'm 90% sure it isnt a virus, I am currently using Trend Micro Titanium. 3 full scans have indicated no malware OR viruses.
@i7baby CPU: i5 4570 3.2Ghz
Motherboard: ASUS B85M-E mATX
RAM: Avexir C9 1600mhz DDR
SSD: Samsung Evo 128ggb
HDD: Seagate Barracuda 7200rpm
GPU: R9 270X Black Edition
PSU: XFX 550w
OS: Windows 8.1 64bit
Monitor: Asus VS247HR 24.6" 2ms response.
GPU isn't overclocked
http://i.imgur.com/vxFk0PR.png is image to what came up.
Sorry about the delay, very slow.
