G
Guest
Guest
Hey guys, only really getting into the whole PC and gaming scene, so basically i'm absolutely clueless!!
This is the first time i actually attempt this myself.
Installed all my hardware, very carefully, according to user guide.Don't exactly know what's the next correct step to follow after this as i get a bit lost with all the terms and acronyms.
This is what i didwith a clean formatted drive)
*started up
went into setup(bios), boot tab, set cd-rom as primary boot
*loaded windows 7 x64 and booted from disk, after i saved,exited & restarted.
*installed completely(all is well)
*after finish, inserted motherboard support disc
*installed all drivers then restarted after prompt.
Then it says, directly after restart:
ECHO is off
Welcome to ASUS Motherboard Make Disk for Dos menu
1) Intel 32-bit AHCI/Raid Driver Disk
2) Intel 64-bit AHCI/Raid Driver Disk
3) JMB36X 32-bit AHCI Driver Disk
4) JMB36X 64-bit AHCI Driver Disk
5) FreeDOS command prompt
Please choose 1 - 5:
*If i choose 1-4 it asks to enter floppy disc. i don't have a floppy disk drive. I also don't know any DOS prompts.
Do i need to get a floppy drive or how can i fix this?? This is probably a stupid question, but as i don't know to much about this, i'm completely stumped!!
System:
Asus maximus III GENE
Intel i5 760 quad
4gb 1600Mhz
Geforce gts450
Samsung 80gb sata drive
Tried with Windows 7 64-bit & Windows XP(Full format & fresh install with both)
Can anyone please help??!
THANK YOU!!
*started up
ECHO is off
System:
Intel i5 760 quad
4gb 1600Mhz
Geforce gts450
THANK YOU!!
