I never had problems with the connection using a Ethernet lan cable. But yesterday after turning on the PC it suddenly shows that there's no internet even though the cable is plugged in. I plugged the cable into another PC and wired connection works perfectly on it. Plugged it back into the first PC, still no internet. When I click on internet option, there is no way to choose wired connection, only the available wifi connections. It's as if the PC can't detect there is a lan cable plugged in. Restarting the PC or router did not solve the issue.
The really weird thing is that I was able to connect to the internet via wifi briefly after turning on the PC, even though my PC doesn't have wifi antenna! How's that even possible? But now I can't connect to the wifi anymore either, it says can't connect to this network.
I didn't change anything on my PC, both physically or internally. Anyone know what might have caused the problem? I can still see the green light on the motherboard ethernet port, but the orange light that usually flashes is gone.
thanks
Thanks.
thanks
Thanks.
