Question PC not booting after power outage
Buildoman
12
Hello, a power outage happened last night while my computer was off and it will no longer turn on. There is a small light visible on the GPU, but no fans or other lights.
So far ive-
Cleared CMOS (removed battery)
Tried a different PSU (no success)
Reseated all cables + ram
Only semi-success I had was shorting the power pins which did turn fans on briefly, and peripherals lit up but then all turned off very quickly.
Computer is less than a year old so nothing should have worn out yet. Any idea what’s causing this?
So far ive-
What is your PSU that you were using and the PSU you used differently?
